THE BIG E Posted November 23, 2008 Share Posted November 23, 2008 i have a 2006 ds 650 x and wont start up i have clean the carb so many times and it wont not run at all. so what could be the problem Quote Link to comment Share on other sites More sharing options...
busa boy Posted November 23, 2008 Share Posted November 23, 2008 If its getting fuel? then is it getting spark? Quote Link to comment Share on other sites More sharing options...
dunefreak Posted November 23, 2008 Share Posted November 23, 2008 ^ yeah what he said. Start w/ checking the basics. ...or maybe you flooded the hell out of it with carb cleaner! :rockwoot: If that doesn't work put some 26's on it. :B Quote Link to comment Share on other sites More sharing options...
THE BIG E Posted November 24, 2008 Author Share Posted November 24, 2008 (edited) i have also clean and check the spark plugs for spark and it looks good Edited November 24, 2008 by THE BIG E Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted November 24, 2008 Share Posted November 24, 2008 petcock turned off? check the coil...could be that too. Quote Link to comment Share on other sites More sharing options...
busa boy Posted November 24, 2008 Share Posted November 24, 2008 I would shoot some starter fluid in there. If the engine fires of for a little then it means that your dealing with a fuel problem, if not the it is an electrical problem. lets see what the other guys say Quote Link to comment Share on other sites More sharing options...
THE BIG E Posted November 24, 2008 Author Share Posted November 24, 2008 well i will give them a try Quote Link to comment Share on other sites More sharing options...
sMitty Posted November 24, 2008 Share Posted November 24, 2008 well i will give them a try Had the same problem with mine and after believing the carb was clean, it wasn't....I redid it and found a clog.... How about the fuses? Quote Link to comment Share on other sites More sharing options...
aceisback Posted December 11, 2008 Share Posted December 11, 2008 Is this problem solved? Just found the thread, sorry. Quote Link to comment Share on other sites More sharing options...
