Sandfrk33 Posted January 10, 2009 Share Posted January 10, 2009 My last trip out to the dunes, my water heater quit working. It still works when I switch it to electric, but not with gas. Anyone know anything about them, or should I quit being a cheapskate and take it in. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
draggindre Posted January 10, 2009 Share Posted January 10, 2009 last weekend @ outlet center mine reset light for the water heater kept coming on i was wtf but then it would start working again a few hours later the frige light started flashing and i found out my dumb a$$ was just out of gas lol im not sure what ur prob may be but i have found out in my practice its usualy something easy good luck Quote Link to comment Share on other sites More sharing options...
RUn2it Posted January 10, 2009 Share Posted January 10, 2009 How bout some info on that water heater, it might be 1 of those with that overheat safety link in the wires that you can see when you open the access door. If so you can take it off and bypass it to test, my brothers WW has had that happen twice now. The 2nd item to check is the thermocouple, sits in the pilot flame. If it has an electronic ignition / circuit board it can be a head scratcher. Ck for a fuse on the circuit board and try disconnecting and reconnect the elect connections. If the elect ignition works you should hear a clicking as it arcs. good luck. Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted January 11, 2009 Author Share Posted January 11, 2009 How bout some info on that water heater, it might be 1 of those with that overheat safety link in the wires that you can see when you open the access door. If so you can take it off and bypass it to test, my brothers WW has had that happen twice now. The 2nd item to check is the thermocouple, sits in the pilot flame. If it has an electronic ignition / circuit board it can be a head scratcher. Ck for a fuse on the circuit board and try disconnecting and reconnect the elect connections. If the elect ignition works you should hear a clicking as it arcs. good luck. Checked all the fuses and breakers. I've got full tanks of gas. Today I blew 2 lbs of sand out of it with my compressor and still nothing. When I turn it on, it doesn't click or try to light. I'll take it in before next trip. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
bp-guy Posted January 12, 2009 Share Posted January 12, 2009 I would like to know the story behind your avatar... Quote Link to comment Share on other sites More sharing options...
Sandfrk33 Posted January 12, 2009 Author Share Posted January 12, 2009 I would like to know the story behind your avatar... Just another day at the dunes. Single a-arm front end, spindle snapped in half on a ride and I didn't even know it till I got back to camp. Pulled in and it just fell over. Quote Link to comment Share on other sites More sharing options...
