tylerthehucker Posted January 22, 2009 Share Posted January 22, 2009 i have a clarion max685bt indash with the matching nax980hd navi system. i have everything else hooked up perfectly, im just wondering if any of you know where EXACTLY the vss is located? i know it is gray with a black stripe, i just am not able to locate it. any specific instructions on where to look would be greatly appreciated. even if your not 100% sure, any help at all is better than no help. thanks in advance! Quote Link to comment Share on other sites More sharing options...
Howie Posted January 22, 2009 Share Posted January 22, 2009 Either back of transmission or rear diff. My F-150 was on the side of the tranny. I think my 02 F-350 reads from the diff. Quote Link to comment Share on other sites More sharing options...
Howie Posted January 22, 2009 Share Posted January 22, 2009 I just found this. Pin-58 on the F250 and F350 Superduty. The PCM is located on the driver's side of the firewall Quote Link to comment Share on other sites More sharing options...
tylerthehucker Posted January 23, 2009 Author Share Posted January 23, 2009 I just found this. Pin-58 on the F250 and F350 Superduty. The PCM is located on the driver's side of the firewall i have a print out a wiring diagram that tells me that too. i dont understand what 'pin (insert number here)' means though. like... where do i find the location of any of the pins?? ps: ive found the pcm already. thanks for the response Quote Link to comment Share on other sites More sharing options...
Howie Posted January 24, 2009 Share Posted January 24, 2009 The pins are the pins inside the connector that plug into the PCM. You should be able to find the wire back a couple inches from the connector, and tie into it there. Quote Link to comment Share on other sites More sharing options...
tylerthehucker Posted January 24, 2009 Author Share Posted January 24, 2009 ok i think i have an idea on where to look. thanks buddy!! Quote Link to comment Share on other sites More sharing options...
