extreme axle boot help!
xtremetoyzracing
you got a number for them?
Looking at them.. the guy on Glamis is right they are Jess axles.. lol i didnt look close at them earlier( i hadd a set on my old car)
(530) 877-2875 jess
Call him and he will send a couple boots....BTW what are you running them on? motor?
Capt
Do your homework with those before you install them. Some people have had no problems and others have had major $$$$ problems. Broken transmissions, even breaking frames at the lower control arms due to incorrect angles.
I personally like having a CV joint be my weak link. $100 is far better than tearing apart a trans or frame.
Not saying you are going to have trouble just make sure whatever frame your going to install it in is going to be ok with this setup. Check with the manufacturer of your frame.
Alot of the failures I have seen or read about have been in high horsepower cars also.
