honda v6 info
barefoot bob
which 6 cyl is the best one to look for to put a turbo on pump gas through ??
are engine mods needed for 6 to 8 lbs of boost??
what kind of power can you expect out of a honda v6 with a 6 to 8 lb turbo ???
3.5 honda and Id ask randizzle or JOEDUNER the rest.
Depends if you go with the SOHC J30 which is the Honda v6 3.0 or the J35 Honda v6 3.5. Ive seen the J35 with turbo pump over 400 horse power to the wheels. Now you can also go with the C32B which is the older series honda v6 engine that has dual over head cams. It was used in the Acura NSX. There is a engine distributor in Ontario California called CT Engine. Thats where i used to get all of mine in my drag strip days.
Randog or Crusty (if you can find him) Crusty got a crate long block for $1200 delivered to his shop before he got back from a Glamis rod through block trip, if I remember the story right. Randogs car sounds like a blender eating the sand at full boost!
Hey Bob,
I'm not a guru, mainly because I've had lots of good luck with my set-up.
It's a J35 3.5L 10lbs of boost. Stock pistons and rods. Stock computer.
Got five seasons out of it so far. Guess the trick is to baby it and it will last.
The Honda motors are like 10:1 compression stock,
so if you boost to 7lbs I'd suggest 110octane minimum.
At that boost I think you'd be lookin' at about 400HP.
Mine still runs hard on the peddle but doesn't idle smooth like it used too.
I realize I'm living on borrowed time with mine, but like Lee said,
Crusty can buy a short block for $1200 with a few valves too. :think:
Hope that helps, and good luck to whom ever is looking to use the Honda power plant. :laughing:
R-
:randog:
Hey Bob,
Hope that helps, and good luck to whom ever is looking to use the Honda power plant. :beerpint:
R-
:randog:
:laughing:
Hey Bob,
R-
:randog:
ummm errrrrmmm randog you must have meant other people baby them to get them to last.
and if you can get all those seasons on a stock internal j35 i am completely convinced that motor is an excellent candidate.
chris is the mexican guy with that chenoweth lt with the vw in it . he camps with me and james and cpt its not powdered yet. anywase i think hes serious now got some good info on gd j35a4 from 20002 to 2004 from the odysee or pilot. found a stainless steel turbo exaust. a stock ecu stripped of the non essentials. we be lookin for a mo mo at the moment :sophie:
but yes i was waiting for you to reply here.
Edited by barefoot bob
Hey Bob,
Crusty can buy a short block for $1200 with a few valves too. :beerpint:
Hope that helps, and good luck to whom ever is looking to use the Honda power plant. :driver:
R-
:randog:
At 10 lbs boost that is IMPRESSIVE, better find some wood to knock on :D
Edited by raspadoo
Man I miss that car....
CApt
the j35a4 is a good engine
you can run 5lbs with 91 or better pump gas and stock computer and should be around 400hp
i ran mine at 8lbs with 110 race gas just to be safe should have been in the neighborhood of 450 ish hp that was also with a stock comp
never had 1 problem with it in 2 years with a 4e hooked to it
  • Like 1
Well by looking at your avitar... looks like you baby yours also lol :beerpint:
Capt
I know that cars that have those motors in them are some of the fastest I have seen. Predu's car was balls out fast.
yeah unfortunatly WAS fast . now if i can just get the rhino to wheelie LOL
yeah i ran the sh*t out of it, and i think it loved it
