F250 problems
THE BIG E
i have an 01 ford f250 am i am having some alignment problems when when i drive the truck it does not go straigth and it all way's want to got to the rigth. so the next day i took it to the alignment shop and they told m that the trucks alignment was good and it did not needed adjustments and they could not find out what is the prodlem so what could it be???
Edited by THE BIG E
i have an 01 ford f250 am i am having some alignment problems when when i drive the truck it does not go straight and it all way's want to got to the right. so the next day i took it to the alignment shop and they told m that the trucks alignment was good and it did not needed adjustments and they could not find out what is the problem so what could it be???
ball joints? wheel bearings? are you sure it wasn't hit... if it doesn't run straight, I would find a shop with an old alignment setup.... Like George's in Las Vegas.
did they put it on the alignment rack? did they give you a print out that shows everything within spec? are you sure that its an actual pull to the right and not just a crooked steering wheel? if you paid for an alignment and it still pulls, go back and b!tch, if its a reputable place they'll re-do it, make sure you get a print out......your best bet is to take it to a ford dealer, they know what to look for ie worn ball joints, bushings etc.
I think i would take it to the dealer to have that check out because i have gone to the shop twice only paid once and did not knew what could be the problem has this happend lately to other ford trucks lately or could this be a factory recall
Other than being a Ford, sounds like it could be a tire. lol Serious though. Rotate the tires like predu said and see if it changes.
Well i have rotated the tires and also i went down to have them balanced and still the same thing
Edited by THE BIG E
Balance of the tires won't have anything to do with it.
So the shop charged you for an alignment and couldn't tell you why it was pulling to the right? :beercheers: I'd ask for my money back.
i am an ASE cert. master tech....i have a couple of questions...have you rotated your tires from left to right...to see if it pulls the other direction...if so...then the problem is in your tires. 2nd...what suspension do you have..."twin I beam" , solid, SLA (dual control arms) ..3rd... did you get a printout of the alignment check...i would like to know the numbers... and does the tires wear funny>.IE...feather,cupping, side cupping, feather inside and out or front to back, inside or outside wear, and tire pressure...let me know...i can probably figure out your problem
you can call me if you like...i do this (phone diagnosing all the time)
760-792-2966 Jason
Edited by JasonR
760-792-2966 Jason
1. (stock) twin i beam suspension
2. The numders are for the front left are for the front rigth are
actual and specified range
0.2 -0.4-1.6 camder -0.4 -0.4-1.6
4.5 2.0-6.0 caster 3.6 2.6-6.0
0.04in -0.06-0.07in toe 0.03 2.0-6.0
11.7 sai 11.5 -0.06in-0.07in
11.9 included angle 11.1
turning angle diff
front
cross camber 0.6
cross caster 0.9
cross sai 0.2
total toe 0.7in
cross turn diff
sorry i am a ford master tech it stomps your ase lol
the caster is the problem 4.5 on left and 3.6 on right will pull right
have them put about 4.0 on left and 4.5 - 4.7 on right and it will go straight
and also no charge for my tech knowledge LOL
LOL...you beat me ....but i agree.. your cross caster is to high... . caster will pull to the most Negative, thus your right side is quit a bit lower then the left..(.9) it will pull to the right. ask them why they didn't offer you caster/camber bushing to correct the problem...you want less then .5 degree spread from left to right...and text book alignment should be negative .5 degree to slightly pull to the left so that the car will compensate for road crown.
my charge for tech advise is a cold beer :headbang1: lol
Edited by JasonR
are thare any good alignmnet shops that would change the casters and would align the truck in or near los angeles california
Edited by THE BIG E
sorry i cant help you with that one..i live in apple valley...but i can tell you that you need .5 degree bushing on either side...preferably on the right...now im not sure what bushing if any you have already but what ever it is ad .5 degree to it and tell the tech to make the appropriate adjustments. IE(if you already have a 3.2 degree...you want to put in a 3.7) you want the 3.6 to be closer to 4.1... that would make the caster spread. +.4 and that would make your car drive straight.
BEER ME....LOL :laughoff::lol::laughing: :beer_bang:
I will do that thanks :slap:
actually 4.1 0n the right will still go right.....WRONG AGAIN
you need the 3.6 to be about 5.0 ....with 4.5 on left
and no such thing as a 3.2 or 3.7 degree cam. are you trying to quote a book or pamphlet????????? AND AGAIN
also it is not the split that is the problem is is the direction of the split ........... AND AGAIN
you should reread my post you might learn something.
