iweb Posted December 1, 2009 Share Posted December 1, 2009 What does it take to convert a swing axle rail to irs? Is there a kit and would it be easier if I have a irs car donor? Quote Link to comment Share on other sites More sharing options...
EY3BA11 Posted December 1, 2009 Share Posted December 1, 2009 http://www.dansperformanceparts.com/buggy/...ysusp%20IRS.htm all the parts are there. You will need to weld in inner trailing arm mounts (IRS Conversion Clips) you will need spring plate eliminators and you will need trailing arm with all the necessary stuff. Not to mention bushings and so on and so forth. Give Dans Performance a call im sure they will point you the right direction Quote Link to comment Share on other sites More sharing options...
avduner Posted December 2, 2009 Share Posted December 2, 2009 You still need about $150 in parts and someone that can weld! Quote Link to comment Share on other sites More sharing options...
