jaytoland80 Posted January 15, 2010 Share Posted January 15, 2010 I am trying to deceide if I should run Fox coil over's or air/nitrogen shocks on the front and rear I am trying not to be cheap but I also do not have a ton of money and I don't want to cut corners on this. The difference in price is around $300.00 :freakin_nuts: Quote Link to comment Share on other sites More sharing options...
Don29palms Posted January 15, 2010 Share Posted January 15, 2010 Coil overs are infinitely more adjustable and will give you a better ride. In my opinion it would be well worth the extra expense. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted January 15, 2010 Share Posted January 15, 2010 coil overs all the way...no matter what kind of car Quote Link to comment Share on other sites More sharing options...
FireKracker Posted January 15, 2010 Share Posted January 15, 2010 When I first got my car, it had 2" fox air shocks and I was impressed at how much they would absorb at low to medium speed n the whoops, but they would aways bottom out in the dunes so I adjusted up in the NTG and the ride went to shait.... my wife drives the car most of the time so safety is a major concern, if you blow out an air shock at a bad time, life will suck!!... I went with 2 1/2" King coilovers and once I got them dialed....it was probably th best 2 grand I spent on the car..... Quote Link to comment Share on other sites More sharing options...
bp-guy Posted January 15, 2010 Share Posted January 15, 2010 If an airshock fails on you, you have nothing to back it up. With a coilover you will always have the spring there for support. $300 might seem like alot of money right now but once you do it right you will be happy in the choice. Do the coilovers and you will never look back. Quote Link to comment Share on other sites More sharing options...
Just Mike Posted January 15, 2010 Share Posted January 15, 2010 I am trying to deceide if I should run Fox coil over's or air/nitrogen shocks on the front and rear I am trying not to be cheap but I also do not have a ton of money and I don't want to cut corners on this. The difference in price is around $300.00 I loved the way my air shocks rode and the adaptability. I would not have them again though. I was once cruising through some whoops when one went to hell. The front end of the car just dropped and and would not come back up. If that were to happen when dunning fast it may have been a few cart wheels. Quote Link to comment Share on other sites More sharing options...
FE135 Posted January 15, 2010 Share Posted January 15, 2010 One more for coil overs, for all the good reasons above. Quote Link to comment Share on other sites More sharing options...
Don29palms Posted January 16, 2010 Share Posted January 16, 2010 Look at it this way. It will be way more expensive to go with air shocks because in the end you'll buy coilovers anyway. So why end up buying 2 sets of shocks? Quote Link to comment Share on other sites More sharing options...
jaytoland80 Posted January 16, 2010 Author Share Posted January 16, 2010 Ok thanks for all your input. I guess coil over's it is. I am actually found a pretty good deal on both front and rear for $1200 for the 10" Front and 14" rear. Quote Link to comment Share on other sites More sharing options...
Don29palms Posted January 16, 2010 Share Posted January 16, 2010 (edited) Try these guys. F-O-A Off-Road Shocks Edited January 16, 2010 by Don29palms Quote Link to comment Share on other sites More sharing options...
lonzo Posted January 18, 2010 Share Posted January 18, 2010 x 2 FOA's! Quote Link to comment Share on other sites More sharing options...
