racegirl04 Posted February 19, 2010 Share Posted February 19, 2010 What's the longest you would go percentage wise before you change your fuel filter? Mine's at 38% now, is 20% too long to wait? Quote Link to comment Share on other sites More sharing options...
andydew Posted February 19, 2010 Share Posted February 19, 2010 What's the longest you would go percentage wise before you change your fuel filter? Mine's at 38% now, is 20% too long to wait? I believe this is a preset manufature's suggestion. I'd run it all the way down to 0, if it hasn't given you any symptoms of a plugged filter. I've run biodiesel through them, and haven't had any issue yet. Personally though, I carry a spare in my vehicle just in case. Quote Link to comment Share on other sites More sharing options...
Just Mike Posted February 19, 2010 Share Posted February 19, 2010 I have run mine past zero and beyond. I have known people to wait till 40,000 miles without having any problems. I always try to change it when the computer says to but does not always happen. Quote Link to comment Share on other sites More sharing options...
mex450 Posted February 19, 2010 Share Posted February 19, 2010 (edited) LISA PLEASE DO IT EVERY 10,000 TO 12,000 MILES ITS BEST FOR UR TRUCK !!!DONT RISK ANYTHING Edited February 19, 2010 by mex450 Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted February 19, 2010 Share Posted February 19, 2010 i have an 03, and the DIC doesnt have a fuel filter percentage most guys at the diesel place recommend doing it every oil change...or 5 to 10k...along with your allison spin on filter i can tell when my fuel filter is plugged ,as the engine tends to get sluggish Quote Link to comment Share on other sites More sharing options...
sanddunesaddict Posted February 19, 2010 Share Posted February 19, 2010 10,000-12,000 15k tops. Todays fuel is so dirty.It may last longer but fuel mileage and performance will be down. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted February 19, 2010 Share Posted February 19, 2010 I change mine every 2-3 oil changes. There's no way I'd let mine get anywhere near 0% on the monitor. 40K Mike? I bet those people would think twice if they saw how much restriction that filter was causing. I remember Joe Duner went like 30 mi. I put a vacuum gauge on his fuel svc port and it was pulling like 20 inches of vacuum. Max at idle should be 5. Quote Link to comment Share on other sites More sharing options...
Jakster884 Posted February 19, 2010 Share Posted February 19, 2010 Don't have chevy. But I would not go over 15k max. Dirty fuel is bad for the injectors. Quote Link to comment Share on other sites More sharing options...
andydew Posted February 19, 2010 Share Posted February 19, 2010 I change mine every 2-3 oil changes. There's no way I'd let mine get anywhere near 0% on the monitor. 40K Mike? I bet those people would think twice if they saw how much restriction that filter was causing. I remember Joe Duner went like 30 mi. I put a vacuum gauge on his fuel svc port and it was pulling like 20 inches of vacuum. Max at idle should be 5. ? How many miles are accumulated when the DIC says 0%? ?Does the % reading actually monitor the vacuum, or is it a mileage thing like the oil % is? We change our filters every oil change, but occasionally 1 will plug. On the big rigs, a plugged filter is just that: low performance (low power) Never caused any damage, never saw a mpg drop; ran 2 engines to a million miles, with never an issue. Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted February 19, 2010 Share Posted February 19, 2010 ? How many miles are accumulated when the DIC says 0%? ?Does the % reading actually monitor the vacuum, or is it a mileage thing like the oil % is? We change our filters every oil change, but occasionally 1 will plug. On the big rigs, a plugged filter is just that: low performance (low power) Never caused any damage, never saw a mpg drop; ran 2 engines to a million miles, with never an issue. if its anything like the oil filter, it goes by how hard you work the engine, not by mileage. A guy i knew drove to Zona to pick up a 39 ft WW 5vr with a front slide. He had his oil changed before he left town. It was below 50% when he got back to bako Quote Link to comment Share on other sites More sharing options...
andydew Posted February 20, 2010 Share Posted February 20, 2010 Wow , I stand corrected. I was always under the impression that the oil % was a mileage thing. I checked my fuel filter % on the DIC, and it's at 40%. So am I safe to assume it's actually metering vacuum resistance, and not just mileage? Quote Link to comment Share on other sites More sharing options...
dunefreak Posted February 20, 2010 Share Posted February 20, 2010 Andy this should answer your question. This is straight from GM Service Information. Fuel Filter monitor... "Starting in 2005 on vehicles equipped with the 6.6L Diesel engine have a new DIC message "Change Fuel Filter". Information about this message and how to reset it can be found on page 3-8 of the Diesel Supplement Owners Manual or SI Document ID # 1553021. The DIC will display "Fuel Filter Life Percent" on trucks equipped with RPO UK3 (Steering Wheel Controls). This feature will provide the percentage of fuel filter life remaining. The fuel filter life is based strictly off mileage. Once reset to 100 Percent it takes 15,000 miles for it to count down to 0 Percent and display "Change Fuel Filter" on the DIC." As for the oil life monitor... "When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL SOON message will come ON. Change the engine oil as soon as possible within the next 1 000 km (600 miles). It is possible that, if driving under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, the engine oil and filter must be changed at least once a year and at this time the system must be reset. If the system is ever reset accidentally, change the engine oil at 5 000 km (3,000 miles) since last oil change." "Engine Oil Life Engine Oil Life percentage values are based on class 2 messages to the IPC. The IPC requests this value when Engine Oil Life is selected on the DIC. Engine Oil Life is capable of displaying values from 0-100 percent and the OIL LIFE RESET driver warning will be displayed. Pressing the Select button for longer than 5 seconds while Engine Oil Life is displayed on the DIC the value will reset to 100 percent. Display appears as ENGINE OIL LIFE: XXX%." So in short: fuel filter: based on mileage oil life: based on calculations from driving conditions Quote Link to comment Share on other sites More sharing options...
otis Posted February 20, 2010 Share Posted February 20, 2010 I dont have a DMax either, but i change mine every other oil change. Roughly every 10-12k miles.... Quote Link to comment Share on other sites More sharing options...
andydew Posted February 20, 2010 Share Posted February 20, 2010 ^Smart people Just jokin. Thanks for a final answer! So do you personally think running your fuel filter down to 0%, or 15,000 miles, is running an unnecessary risk; assuming you aren't experiencing any symptoms of a plugged filter? Quote Link to comment Share on other sites More sharing options...
dunefreak Posted February 20, 2010 Share Posted February 20, 2010 ^Smart people Just jokin. Thanks for a final answer! So do you personally think running your fuel filter down to 0%, or 15,000 miles, is running an unnecessary risk; assuming you aren't experiencing any symptoms of a plugged filter? I wouldn't. You risk doing damage to your motor if you happen to be towing or putting it under a heavy load when the filter finally plugs up. And who knows exactly when that might be? As SDA said, the fuel these days is so dirty you never know what you are getting. I wouldn't go any more than 10-12K but that's just me. I like to over-maintain my vehicles. They last forever that way. Quote Link to comment Share on other sites More sharing options...
andydew Posted February 20, 2010 Share Posted February 20, 2010 I tend to over maintenance as well. A stitch in time saves nine, right? Thanks for sharing, good to hear it from the chevy man . Any ominous warnings for me about running biodiesel? ? Quote Link to comment Share on other sites More sharing options...
racegirl04 Posted February 20, 2010 Author Share Posted February 20, 2010 Thanks all! Quote Link to comment Share on other sites More sharing options...
dunefreak Posted February 20, 2010 Share Posted February 20, 2010 Any ominous warnings for me about running biodiesel? :argue: ? yeah...DON'T! Quote Link to comment Share on other sites More sharing options...
sanddunesaddict Posted February 20, 2010 Share Posted February 20, 2010 ^^^^^I have nothing worth adding to this post!! - I have nothing worth adding to this post!! - I have nothing worth adding to this post!! - x2 Quote Link to comment Share on other sites More sharing options...
dunefreak Posted February 20, 2010 Share Posted February 20, 2010 ^^^^^I have nothing worth adding to this post!! hahaaa busted by the classic "X 2" word filter Quote Link to comment Share on other sites More sharing options...
vegas style Posted February 20, 2010 Share Posted February 20, 2010 the fun continues.... Quote Link to comment Share on other sites More sharing options...
barefoot bob Posted February 20, 2010 Share Posted February 20, 2010 the fun continues.... x 2 Quote Link to comment Share on other sites More sharing options...
dunefreak Posted February 20, 2010 Share Posted February 20, 2010 no space, bob haha Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted February 20, 2010 Share Posted February 20, 2010 hahaaa busted by the classic "X 2" word filter the fugger got me me with it too Bert Quote Link to comment Share on other sites More sharing options...
sanddunesaddict Posted February 20, 2010 Share Posted February 20, 2010 WTF?? When did that come about?? Quote Link to comment Share on other sites More sharing options...
