mex450 Posted February 20, 2010 Share Posted February 20, 2010 (edited) i'm thinking of removing my stickers off my rzr any good advise on how to take them off? Edited February 20, 2010 by mex450 Quote Link to comment Share on other sites More sharing options...
BIG DAVE XP1K Posted February 20, 2010 Share Posted February 20, 2010 i'm thinking of removing my stickers off my rzr any good advise on how to take them off? I removed mine with a heat gun. just get the sticker hot not the plastic be very carefull any additional adhesive left in the plastic use WD-40 to remove that.. Be REAL CAREFUL with that heat gun though Quote Link to comment Share on other sites More sharing options...
mineurbiz Posted February 20, 2010 Share Posted February 20, 2010 I think this is what we used on the adhesive left behind after removing body molding on a truck I use to own. http://www.tcpglobal.com/autobodydepot/ite...itemno=MMM+7498 Quote Link to comment Share on other sites More sharing options...
BIG DAVE XP1K Posted February 21, 2010 Share Posted February 21, 2010 I think this is what we used on the adhesive left behind after removing body molding on a truck I use to own. http://www.tcpglobal.com/autobodydepot/ite...itemno=MMM+7498 WD-40's primary base ingredient is fish oil it is harmless to the plastic as well as the finish you could spray a whole can on your RZR and leave it over night without fear of any damage at all plus whats a can of WD cost? $5 its your call bro Quote Link to comment Share on other sites More sharing options...
mineurbiz Posted February 21, 2010 Share Posted February 21, 2010 WD-40's primary base ingredient is fish oil it is harmless to the plastic as well as the finish you could spray a whole can on your RZR and leave it over night without fear of any damage at all plus whats a can of WD cost? $5 its your call bro HUMM... just trying to give him options Quote Link to comment Share on other sites More sharing options...
mex450 Posted February 21, 2010 Author Share Posted February 21, 2010 thanks guys!!!!! Quote Link to comment Share on other sites More sharing options...
otis Posted February 21, 2010 Share Posted February 21, 2010 I think this is what we used on the adhesive left behind after removing body molding on a truck I use to own. http://www.tcpglobal.com/autobodydepot/ite...itemno=MMM+7498 I used that 3M wheel when i debadged my truck... It works awsome! I removed mine with a heat gun. just get the sticker hot not the plastic be very carefullany additional adhesive left in the plastic use WD-40 to remove that.. Good tip on the wd40. I'm gonna try that when (if) i get around to removing the safety warnings plastered all over Quote Link to comment Share on other sites More sharing options...
BLUE STEEL Posted February 21, 2010 Share Posted February 21, 2010 I removed mine with a heat gun. just get the sticker hot not the plastic be very carefull any additional adhesive left in the plastic use WD-40 to remove that.. Be REAL CAREFUL with that heat gun though Heat Gun and WD-40. I have nothing worth adding to this post!! - I have nothing worth adding to this post!! - I have nothing worth adding to this post!! - x2 (Big Dave has never steered me wrong) Quote Link to comment Share on other sites More sharing options...
CHOPJAW Posted February 22, 2010 Share Posted February 22, 2010 Hey Dave, ZIP TIE gun. Me still thinks it's the coolest. Quote Link to comment Share on other sites More sharing options...
BIG DAVE XP1K Posted February 22, 2010 Share Posted February 22, 2010 Hey Dave, ZIP TIE gun. Me still thinks it's the coolest. Ya its not near as cool as Marks mirror though :ahhhhh: but it is readaly available!!!! Whats going on with those doors on the RZR4 Quote Link to comment Share on other sites More sharing options...
BIG DAVE XP1K Posted February 22, 2010 Share Posted February 22, 2010 (edited) I used that 3M wheel when i debadged my truck... It works awsome! Good tip on the wd40. I'm gonna try that when (if) i get around to removing the safety warnings plastered all over Here is the opinion, I dont claim to be the formost expert in removig adhesive. How ever I do tend to base many of my opinions on common sense and experience. Here is my thoughts on this issue: We are talking about removing adhesive from a plastic body panel not a metal one. I have no doubt that the wheel method is very effective on a metal car body, but what we are talking about is removing adhesive from plastic with a revolving wheel turning at 3600 rpm.This is more likely to damage the PLASTIC by causing HEAT and friction, then a can of fish oil with no heating or abrasive qualitys. :ahhhhh: Considering the material being worked on is as important as the product you are working on it with. Just my opinion... Edited February 22, 2010 by Big Dave Quote Link to comment Share on other sites More sharing options...
RangerZ Posted February 23, 2010 Share Posted February 23, 2010 When I took all of my safety stickers off, I used a hair dryer (less chance of a screw-up !) and Goof Off. WD-40 will work as well. Final clean up with Denatured Alchohol. Just go slow and you should be fine! Quote Link to comment Share on other sites More sharing options...
mex450 Posted February 27, 2010 Author Share Posted February 27, 2010 When I took all of my safety stickers off, I used a hair dryer (less chance of a screw-up !) and Goof Off. WD-40 will work as well. Final clean up with Denatured Alchohol. Just go slow and you should be fine! ranger z thanks man the hair dryer worked well .... finish it will wd 40 lil buff done !! thanks everyone :poop: Quote Link to comment Share on other sites More sharing options...
