jwcarguy Posted August 28, 2010 Share Posted August 28, 2010 I have a new Wilwood single master cylinder pedal assembly for clutch or brake use , forward swing mount Part #340-1290 Wilwoods description: This pedal is often used as a clutch pedal with a single outlet master cylinder, or as a brake pedal in conjunction with dual outlet, tandem master cylinders on four wheel brake equipped vehicles. The pedal features all aluminum frame and arm construction with steel pivots, mounting studs, and an anti-skid pedal pad. Swing mount mount with a 7.00 to 1 pedal ratio. Notes & Cautions: Pedal can be adapted to use tandem master cylinder w/ horizontal mounting, use adapter 250-3677. $55 shipped (lower 48) JeffW_01@msn.com In Las Vegas (702)677-4085 Quote Link to comment Share on other sites More sharing options...
