Doghouse Posted December 8, 2010 Share Posted December 8, 2010 So I have a brand new Brazilian AS41 case in my shop that has already been cnc clearanced for a stroker crank & rods. It has already had extensive machine work done to it to accept a Scat 88 crank with t4 mains and flanged flywheel. It's been drilled for piston squirters, full flow tapped, all gallies drilled & tapped, opened for 94 jugs, decks cut and 10mm case savers. So a lot of money has already been spent on this block...to much to just toss it. All that being said, the reason for this topic question: While attempting to gain more clearance for the rods being used, I cut right through the top of the block with my rotary bit. The hole is large enough that I can almost put the end of my little finger in it. It's located on the DRIVER SIDE of the blocks top, right by the hole that utilizes the pass through bolt. MY QUESTION IS THIS: has anyone been successful in welding a pop though hole like this, IN THAT LOCATION? My customer doesn't want me to use JB Weld. my e-mail is feedback@doghouserepair.com thanks for any input, Phil Quote Link to comment Share on other sites More sharing options...
turbo_bruce Posted December 8, 2010 Share Posted December 8, 2010 So I have a brand new Brazilian AS41 case in my shop that has already been cnc clearanced for a stroker crank & rods. It has already had extensive machine work done to it to accept a Scat 88 crank with t4 mains and flanged flywheel. It's been drilled for piston squirters, full flow tapped, all gallies drilled & tapped, opened for 94 jugs, decks cut and 10mm case savers. So a lot of money has already been spent on this block...to much to just toss it. All that being said, the reason for this topic question: While attempting to gain more clearance for the rods being used, I cut right through the top of the block with my rotary bit. The hole is large enough that I can almost put the end of my little finger in it. It's located on the DRIVER SIDE of the blocks top, right by the hole that utilizes the pass through bolt. MY QUESTION IS THIS: has anyone been successful in welding a pop though hole like this, IN THAT LOCATION? My customer doesn't want me to use JB Weld. my e-mail is feedback@doghouserepair.com thanks for any input, Phil is the case alum or mag???? alum is easy mag not so easy Quote Link to comment Share on other sites More sharing options...
bp-guy Posted December 8, 2010 Share Posted December 8, 2010 Can you post a picture? Not sure what you mean by "pass thru bolt" I know VW's are weak around the #3 jug due to cooling concerns. I believe if it is a Brazillian case it is going to be magnesium. It should still be salvageable depending on the size of hole but I am not sure on the proceedures on plugging a magnesium case. Quote Link to comment Share on other sites More sharing options...
Doghouse Posted December 8, 2010 Author Share Posted December 8, 2010 it's off to Rimco Quote Link to comment Share on other sites More sharing options...
jalper Posted December 11, 2010 Share Posted December 11, 2010 That is a pretty common area for a stroker, Jon at RC Trans, welds mag all the time, I can have Brad From Canyon Concrete Pick up the case and drop it off to save you the 45 minutes? Or Phil Hayes on Bender street can weld it up in his sleep or with the 6 CNC machines one being almost two storys could even make one, If you go to Phil's Tell Him Jason Alper sent you I worked for phil for 5 years, in the stock car days at the bull-ring he was know as the Mad-Hater, his shop in vegas was the old national performance building on fremont street. Very well know in Las Vegas. Phil Hayes Inc 6910 Bender Street Pahrump, NV 89060-3059 map Phone: (775) 727-9222 Quote Link to comment Share on other sites More sharing options...
