Buggy Parts
jalper
Made in USA
Billet micro stub rear disc brake kit.
Micro stub rear brakes are engineered to increase wheel travel by relocating the bearing housing and cv joint closer to the wheel. Less cv angle and longer axles will allow more wheel travel over conventional IRS bearing housings. This kit includes rotors, forged chromoly or 300m micro stubs, T-6 billet aluminum hats, T-6 billet wheel adapters, T-6 billet axle nut caps, billet 4 piston calipers with brake pads, lug nuts and hardware (some parts not pictured). The bearing hub assembly is available in the standard heavy duty assembly or in a Made in USA chromoly housing designed with larger double tapered bearings and grease seals. The Made in USA chromoly housing is machined with grease fittings and the bearings are replaceable for many years of reliable service.
$1150.00 For 930.
$1250.00 For 934
934 / 930 CV spline Made in USA 300M race axles. These race quality axles are made from the finest materials available. Choose your axle length with 934 cv
These are made local they are not imports.
Front Brakes
Combo Front Brakes $775
2'' Hollow Brakes $875
post-4378-0-95094400-1309034466_thumb.jp
post-4378-0-45659600-1309034475_thumb.jp
post-4378-0-65350000-1309034484_thumb.jp
post-4378-0-50154700-1309034495_thumb.jp
