Ross and Alice Posted September 11, 2006 Share Posted September 11, 2006 Wifes right turn signal quit. Bulbs OK. Did GM still use "flashers", or what do I attack next to correct it? '96 Buick Regal Thanks, - Quote Link to comment Share on other sites More sharing options...
EY3BA11 Posted September 11, 2006 Share Posted September 11, 2006 check da fuse mang! Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted September 11, 2006 Author Share Posted September 11, 2006 Checked that. The signal died a slow death. Must be some sort of relay or Flasher. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted September 11, 2006 Share Posted September 11, 2006 First check for power at the fuse, next you'll want to check power at the signal switch. More than likely it's a turn signal switch. What model is the car? Does the turn signals light up at all and stay on? How about the 4 way flashers. If you turn them on and figit with the switch and they start to kinda come on, that is a good indication that the switch is bad. That is the most common failure on that year of car. Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted September 11, 2006 Author Share Posted September 11, 2006 Thanks DF, I'll check that out 96 Buick Regal deluxe It's a teriffic car. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted September 11, 2006 Share Posted September 11, 2006 Hope you can read wiring diagrams...if so here ya go. I'm not supposed to give these out, but so what? click on the images for a bigger picture... wiring diagram... flasher location.... Hope that helps some Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted September 11, 2006 Author Share Posted September 11, 2006 Thanks DF, it's the problem. I appreciate the help. What's a fair dealer labor charge for replaceing the switch, without holding you to it. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted September 12, 2006 Share Posted September 12, 2006 Thanks DF, it's the problem. I appreciate the help. What's a fair dealer labor charge for replaceing the switch, without holding you to it. The dollar amount depends on the shop's labor rate, but the "Alldata" labor guide calls for about 1.5-2.0 hrs labor. Our dealership charges about $95/ hr. I don't know if CA is about the same or any different. Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks, close enough. I appreciate it. Quote Link to comment Share on other sites More sharing options...
