smttm Posted December 3, 2011 Share Posted December 3, 2011 All New 2332cc Turnkey Engine Watch the Run Video Price: $4500 There are No used or rebuilt parts in the engine. . . Except the Alternator and Carbs This is the best deal on an engine, my price doesn't cover the cost of parts, my loss. . . Total cost of parts is $6521.84 not counting Tax and Shipping so you save over $2000.00 and the work is done. . . Watch the video of the engine on the test stand after the breakin. Call or email James 775-513-3800 84x94 Stroke/Bore Assembled at 9.3:1 Compression Description Original Cost CB Super Case (As41) 829.95 Clearance for Stoke 80.00 Full Flow Case 20.00 Shuffle Pin Center Main 60.00 10mm Case Savers 80.00 CB Super Race 84mm Crank 289.95 Scat Straight Cut Cam Gears 95.95 Crankshaft Assembly Kit 65.00 CB 5.5" H-Beam Super Race Rods 249.95 Weisco Forged 94mm Pistons 389.00 Total Seat Second Ring 89.15 Jaycee Aluminum Piston Buttons 39.95 AA Cut to Fit Cylinders 175.95 Cylinder Machining 160.00 CB Wedge Port Heads 874.95 (65cc Chambers 42/37.5 Valves) W650 Spring Upgrade 79.95 Chromoly Rocker Studs 3.95 CB C-Channel Valve Covers 39.95 Match Ported Manifolds 184.95 Main Bearings 41.00 Double Thrust Cam Bearings 21.42 Crank bearing Dowel Pins 3.95 Erling Crank Seal 6.95 Rubber Cam Plug 10.95 Scat C-35 Camshaft 77.87 CB 31mm Big Foot Lifters 29.95 Scat Chromoly 10mm Head Studs 85.95 Scat 1.25:1 Rocker Assemblies 239.95 Erling Gasket Set 19.95 Empi Engine Hardware Kit 21.95 Empi Oil Pressure Spring Kit 10.95 Crankshaft End Play Shims 6.95 10mm Air Deflector Plates 10.95 CB Super 30mm Full Flow pump 61.95 Oil Screen 6.53 Scat Oil Drain Plate 34.82 Scat Spring Push Rod Tubes 65.95 Gland Nut and Washer 19.95 CB Forged Lightweight Flywheel 109.95 CB Center Mount Fan Housing 149.95 JayCee Billet Oil Filler Cap 19.95 Used 55 Amp Alternator 100.00 CB MagnaSpart II Distributer 197.95 Used Webber 44 Carbs 400.00 CB Crossbar Linkage 44.00 Scat 5 Hole Black Pulley 66.00 Chrome Crank Pulley Bolt 6.38 CB Chrome Off Road Cylinder Tins 40.00 Alternator Nut and Spacer Kit 6.38 Cooling Fan 63.00 Cooling Fan Hardware Kit 11.69 Stainless Alternator Strap 8.50 Billet Fuel Pump Block Off Plate/Breather 45.00 Total of all parts 6094.79 TAX 427.05 Total Parts 6521.84 Quote Link to comment Share on other sites More sharing options...
