jwcarguy Posted May 12, 2012 Share Posted May 12, 2012 (edited) - I have a complete LS1 / t56 dropout from a 2000 WS6 Trans Am (F-Body Camaro SS Z28) that was adult owned and maintained *only the engine is available* (trans is not) the engine is stock with no aftermarket modifications ran excellent prior to removal The complete LS1 engine assembly includes: factory LS1/ M6 engine harness and pcm (#09354896, harness needs a few wires repaired) all front engine accessories (f-body) alternator, p/s pump, a/c compressor, water pump, tensioner & idler pullies stock LS1 intake assembly with dbc (drive by cable ) throttle body stock F-body exhaust manifolds w/ egr tubes (have y-pipe available) starter all ignition coil packs & harnesses all engine sensors will include flexplate for auto transmission (4L60E) also have F-body (Camaro / Firebird) positive / negative battery cable harness SOLD!!! - Factory LS6 Intake assembly complete part# 12573572 complete with fuel rails, injectors, map sensor, seals and throttle cable bracket This intake is a great upgrade for a LS1 or Vortec series truck engines (ie 4.8l , 5.3L , 6.0L LQ4 , LQ9 , etc) ready to bolt on asking $500 - Brand new in box Texas Speed / Comp Cams Tsunami camshaft for gen3 LS / Vortec series engines This cam is brand new, just out of box for pics retail for $389 + shipping specs. valve lift (int/exh) 647/608 dur. @.050 (int/exh) 235/240 LSA 111.0 asking $350 obo - pair of low mileage (28k) cylinder heads and Intake manifold setup off a 2000 C5 Corvette LS1 engine Cylinder Head Casting # 853 cathedral port the heads are complete with rockers , stands, valves, springs, etc. SOLD!!! - complete set ( for two heads) of low mileage (40k) rockers and stands from a 6.0L (will work on 4.8L, 5.3, 6.0 LS1, LS6) $60 for both - one set of 8 brand new GM L92 intake valves 2.165" part #12590771 $30 for set of 8 - stock LS1 "spider" coolant crossover tubes (4 port) used in good shape (2 available) SOLD!! - complete 2002 LQ4, LQ9 6.0L / 5.3L truck intake setup, with (65k miles) complete with fuel rails, fuel injectors asking $75 obo most parts will fit various LS1, LS2, LS3 , LS6 , 5.3, 6.0 L92 engines used in street , pro-touring , offroad sand rail and drifter , drift cars In Las Vegas call (702) 677-4085 Edited May 29, 2012 by jwcarguy Quote Link to comment Share on other sites More sharing options...
jwcarguy Posted May 29, 2012 Author Share Posted May 29, 2012 LS1 engine is SOLD!! LS1 heads are SOLD!! Quote Link to comment Share on other sites More sharing options...
