yfz450man Posted August 2, 2012 Share Posted August 2, 2012 (edited) sold remove sold remove I THINK I HAVE A 1974 FRAME THAT HAS BEEN WELDED ON THE BOTTOM BUT LOOKS GOOD NOT RUSTED OUT IT HAS BEEN PAINTED GRAY. 2 SETS OF 74 FORKS RED, 1 SET OF 73 GRAY STOCK PIPE IS IN GOOD SHAPE NO HOLES OR WELDS. IT IS MISSING THE TIP,GAS TANK NO LEAKS HAS LITTLE DINGS IN IT, SEAT PAN IS GOOD FOAM IN OK , REAR GRAB BAR HAS SCRATCHES ON IT AND 1 DINT, REAR AXLE ASSY IN ALL THERE PLUS 1 EXTRA AXLE SPACER, AND BRAKE HUB, CHAIN ADJUSTER IN THERE, HANDLE BAR ARE GOOD NOT BENT, I MAY HAVE THE BOTTOM FRAME COVER BUT NOT SURE IF IT IS THR RIGHT ONE. ALL YOU SEE IN PIC $200.00 O.B.O. OR IF YOU WANT 1 PART LET ME KNOW WHAT YOU WANT WITH A RESONABLE OFFER AND I MITE SELL IT. WOULD LIKE IT SEE IT ALL GO AT THE SAME TIME. Edited August 18, 2012 by yfz450man Quote Link to comment Share on other sites More sharing options...
yfz450man Posted August 18, 2012 Author Share Posted August 18, 2012 ALL IS SOLD Quote Link to comment Share on other sites More sharing options...
