jwcarguy Posted October 27, 2012 Share Posted October 27, 2012 (edited) I have two Chevrolet LS1 5.7L engines availableI am not the original owner of these, mileage stated from previous owner2000 Camaro Z28 / SS LS1 stock engine w/63k miles (had a 4L60E auto trans behind it)Complete long block engine with LS1 intake w/ rails and injectors, has map sensor and Billet block off platestock throttle body, LS1 coil packs w/ harnessesLS1 cam w/ 198 209dur/ 500 500 lift cam, timing set, lifters & trays, pushrodsbalancer, auto flexplate, LS1 water pumpF-Body oil panno accessories, wire harness/ pcmSOLD!!1999 Camaro Z28 / SS LS1 stock engine w/ 89k miles (had a t56 6 spd manual trans behind it)Complete stock LS1 short block, but comes with set of good #853 heads, set of stock head boltsLS1 cam w/ 198 209dur/ 500 500 lift cam, timing set, lifters & trays, pushrods , valve covershas F-Body balancer and oil pan (pan is cracked and needs repair/ welded?)No intake setup, accessories or wiring / electronicscan throw in a truck intake with rails and injectors for free if wantedSOLD!!99' Camaro Z28 / SS LS1 bare Block for " mock up " and F-body oil pan (bad) (Camaro, Firebird, Trans Am, Firehawk)the block has a rod threw it, so is no goodgreat for used for mocking up your mounts and clearnaces in a LS swap ( pro- touring, sand rail, offroad, buggy, LSX swap, drift car 240 RX7 etc)same dimensions/ bolt pattern as the truck "LS" 4.8 , 5.3 , 6.0 and the LS1 LS2 LS3 LS6 LQ4 LQ9 LY6 L92 enginesBoth are SOLD!!in Las Vegaspm/call/ text (702)677-4085can email additional pics also jeffw_01@msn.com Edited May 11, 2013 by jwcarguy Quote Link to comment Share on other sites More sharing options...
chris&hol Posted November 7, 2012 Share Posted November 7, 2012 Looks like your a ls1 fan. Im on the hunt for a complete ls1 ( minus ecu/harness etc if so) please keep me in mind if you come across any. Thanks Quote Link to comment Share on other sites More sharing options...
jwcarguy Posted November 7, 2012 Author Share Posted November 7, 2012 Looks like your a ls1 fan. Im on the hunt for a complete ls1 ( minus ecu/harness etc if so) please keep me in mind if you come across any. Thanks Will do Chris!! Just sold one complete last this past saturday! I only have a LQ4 6.0L and the LS1 shortblock w/ heads now I know of a complete running car with a LS1 / auto for $3500 give me a call if you need too (702)677-4085 thanks, Jeff Quote Link to comment Share on other sites More sharing options...
