1999 4.3L Silverado engine code
mineurbiz
Its a cat Mark, The sensors can be tested but the only one you need to test is pass
side post cat, An exhaust leak on the same bank will cause this condition. Unless you have an 02 code you can rule that out. If you want a copy of the diag flow charts let me know?
Thanks!! Already been through the ringer on this truck, it is 17 year old kids truck and just trying to help him out. Just had it's ignition module replaced, do to not starting, now this, which looks like over $300 just for the cats now. Hope that this is something I can do myself, rather than paying a shop, but I guess that depends on if it is welded on or bolted.
Time to crawl under this thing and see.
If it is bolted on I suggest you weld it on. Cat's are being stolen all the time. My dads was stolen last year. He said it scared the crap out of hime when he started his Tacoma at 6am!
Good info!! Nothing like a straight pipe Tacoma!!
