FireKracker Posted September 26, 2014 Share Posted September 26, 2014 I'm putting an intercooler on my honda 3.5, was reading on placement of the BOV and there seems to be pros and cons as to where to place it. Hot side to blow off highest pressures and temps (as to not heat soak the intercooler) cold side to keep air flow moving in the same direction and to blow off highest density of air as well as blowing cooler air through the BOV to make the diaphragm last longer..... I am looking for some input to see what others are using and what works for them..... Thanks in advance. Sure do miss Bert, one phone call and would have got what I needed! 1 Quote Link to comment Share on other sites More sharing options...
nwtdiesel Posted October 1, 2014 Share Posted October 1, 2014 I have always put them on the hot side of the IC closest to the turbo possible. I was told long ago and believe that would get the pressure off the turbo compressor wheel the fastest for protection. 2 Quote Link to comment Share on other sites More sharing options...
ltr450rider Posted October 1, 2014 Share Posted October 1, 2014 I understand the reasons for both ways, but I agree with Newly. It seems getting the pressure off the turbo the quickest is the best way. If you want to argue about the diaphragm lasting longer, I would say that the diaphragm is cheaper and easier to replace/service than a turbo is. 1 Quote Link to comment Share on other sites More sharing options...
FireKracker Posted October 2, 2014 Author Share Posted October 2, 2014 Valid points to both comments. I talked with a guy at hondoctor today and his recommendation was to place it on the cold side so the airflow is continuous in one direction and will evacuate faster minimizing what he referred to as a "vein hammer". He said because I am running minimal boost then it shouldn't be a problem with heat soaking. If I intend on running 16 lbs or higher then place one pre and post intercooler. 1 Quote Link to comment Share on other sites More sharing options...
nwtdiesel Posted October 2, 2014 Share Posted October 2, 2014 That works. I do believe the farther away the BOV the more of a chance the compressor wheel can be stressed out or have a chance to slow down or stop. Especially when on the other side of the IC. No matter where you put the BOV its going to help and it will stop the comp wheel from barking and that's its main purpose. Cant wait to see it! 1 Quote Link to comment Share on other sites More sharing options...
