Custom Banshee Turn Key set up and more
Selling my custom built 2002 banshee and all that goes with it. I built this bike for speed and dependability in the dunes. Recent top-end and new clutch plates. I run Yama-lube 40:1 with 50/50 race gas. This bike was a GLAMIS Dune BIKE ONLY, serviced, cleaned, and polished after every trip, looks great and is very fast. This bike turns heads . . ... Call for more info 858-672-8505 0r e-mail $5,500.00 (negotiable) Pink slip in hand.
Engine:
• Dyno Tuned @ 60 hp to the wheels
• Cylinders are Dune Ported and Polished ( Tim Morgan)
• Welded Crank
• Cool Head with 19 cc domes
• FMF Pipes & Silencers
• PWR over size radiator w/ stainless grill
• CV4 silicone radiator hoses
• Pro Design Mega-Flow water pump impeller
• IMS over sized fuel tank w/ Polished Billet Gas Cap
• Keihin 35mm carb's w/Boss Racing Billet oversized bowls
• Boss Racing Billet Cross-over Intake
• Delta V-Force III Reeds
• K & N filter pods
• Polished Motion-Pro Twist Throttle
• UPP Case Saver
Lighting:
• 200 Watt Stator from Ricky Stator (RIP)
• Lightened Flywheel
• 2 Lazerstar Billet 50 Watt lights w/ polished Bar clamp
• 2 Piaa 6" 50 Watt lights
Frame:
• Lone Star +2/+1 Chrome A-Arms
• Chrome Spindles
• Polished Billet Tie Rods
• Stream Line brake lines w/ Polished Billet Clamps
• Elka (Dune Edition) Triple Rate w/ Reservoir and Compression adj.
• Chrome Lone Star Anti --Vibe Steering stem w/ polished Billet Clamp
• Polished Renthal Bars w/MX bend
• Chrome Tucker +4 Round Style Swing arm w/ Lone Star Billet Carrier
• Lone Star +2 Excalibur Axle
• Lone Star Billet Hubs front and back
• Lone Star Billet Sprocket hub and Brake Rotor
• Billet Foot Pegs
• Motion Pro Billet shifter
• R.I.S Billet Rear Brake lever
• R.I.S Billet Kick Starter
• R.I.S Billet Bumper
• R.I.S Billet exhaust hangers and Clamps
• UPP Chain Guide and Rollers
• ASV Levers
• Pro-Design tethered Kill Switch
• O-Ring chain w/13 tooth front and 41 tooth rears
• Stainless Steel bolt kit
All covers are polished, clutch, Stator, Block off plates, Brake Reservoir, Swing Arm Bolt, Front Hub nut Covers, Rear Brake Cylinder, Gas Cap. . ..ETC.
Tires:
• 22x8,00x10 GBC Dune Tracker Razors on Douglas Rims
• 20x10x10 Skat-Trak Haulers on Douglas Rims
• 20x11x10 San Tires Unlimited San Skate II on Douglas rims
Extras:
• Brand New Lone Star Billet Carrier
• Stock Radiator
• Stock Gas Tank
• 7 Two Qt bottles of Yama-Lube, chain lube, filter oil, transmission oil. . .Etc.
• 2 5 Gallon bump cans
• Tie Downs
• O'Neal Helmet w/GO-PRO mount
• SPY tinted goggles w/ Quick straps
post-5965-0-46858100-1414359018_thumb.jp
post-5965-0-14696500-1414359040_thumb.jp
post-5965-0-04732300-1414359059_thumb.jp
post-5965-0-53755400-1414359085_thumb.jp
post-5965-0-03119700-1414359106_thumb.jp
