2010 V8Rail Tri-Sport: Sand, Dirt, and Street. Top Tier Car
Sandblower
Price reduced to $70,000
Offroad Sports Car
50/50 Weight Balanced Car for Supreme Handling
Only 14’ Long… 2’ Shorter than most 4 seat rails
CBM 1000hp LS7, Stroked with Whipple 4.0 Supercharger
Turbo 400 Manu-matic Transmission. Just bump the lever to shift. No Expensive Transaxle!
Speedway Engineering Quickchange Rear End. 100’s of gear ratios to choose from that can be changed in 10 minutes.
934 CV’s and 300M Axles
Width Rear: 97” Fits in Trailer without removing paddles
Chassis: 1 ¾” DOM Tubing
Boxed Lower A-Arms Front and Rear
Completely Cross Braced and Stout as Hell
Rear Sway Bar
17” Custom Bogart Wheels
24” Front Suspension Travel
20” Rear Suspension Travel
King Shocks, Racing Series
Front: 3” Coil Overs and 3” Triple Tube Bypass
Rear: 3” Coil Overs and 3” Four Tube Bypass
Stack Digital Dash: Tachometer, Engine Oil Temperature, Water Temperature, Oil Pressure, Battery Voltage.
Programmable Warning Lights
Gear Indicator
External Auto Meter Gauges: Transmission Temperature, Differential Temperature, Front Brake Pressure, Rear Brake Pressure
Billet Retractable Cup Holders
Jet Trim Seats with Lumbar Support Adjustment on Front Seats
New PRP 3” Padded Seat Belts
New Howe Rack
Just completely re-wired, first class
Tilt Steering Column
PCI Race Radio & Intercom
5” Lowrance Color GPS
6 HID Acro Lights on Light Bar: 2 Floods and 4 Euro Beams
Electric Linear Actuator on Light Bar
On-board fire extinguisher with 5 nozzles: 3 on engine, 1 on electrical/transmission area, and 1 on fuel cell.
3-Quart Oil Accumulator for constant oil pressure
Engine Pre-Lube: Turn on ignition switch and oil flows through motor before starting
Amsoil Dual Oil Filter System with Bypass Filter
Brake Pressure Proportion Control (Front to Rear)
Stereo System, 2 Amps, 10” Sub-woofer, 4 Speakers, Remote Control from Driver’s Seat
Windshield
2 Battery Disconnects: 1 Keyed at Driver’s Seat, 1 Main Disconnect
Upholstered Interior Panels
26 Gallon ATL Fuel Cell
Huge Radiator in Rear of Car
External Engine Oil Cooler with Fan
External Transmission Fluid Cooler with Fan
External Differential Cooler
More pics available.
Paul
559-906-7285
Temecula
Edited by Sandblower
Wow....that's a killer deal
Thanks Joe! It pains me greatly knowing what it cost to get it here. The car just finally got "perfect" this season. The electrical and steering were the last weak links. I spent $15k getting just those two things first class.
Here is a gopro video link. Sanddunesaddict is in some footage. Miss you Bert!
  • Like 1
  • 3 months later...
  • 1 month later...
  • 1 month later...
  • 8 months later...
Sure it is, Paul. I bet it makes the garage looks fantastic. :laughing:
Side note: whats the red car in your profile? You have a 2 seater too? Looks badass.
I bought Roland's car last year and updated it quite a bit. That's why I'm selling my 4 seater.
  • 1 month later...
