Last minute fuel pump for toyhauler
Svengoolie
What is it doing? Did you check the fuses? Sometimes the gears will swell and when you go to pump the gas, the motor binds and will blow the fuse or just not turn. If the fuses are good for the fuel station, try cracking the 4 bolts to the fuel station cover and see if it will turn. If it does work with the cover lose, you can file down the gears to get them to work again, by sanding each flat side and both sides of each tooth to both gears.
Edited by mineurbiz
