foolofsand Posted November 2, 2015 Share Posted November 2, 2015 ok, i have searched high and low for this part. i need the way high upper tail light on my ww th. only thing on thepart is cemm pa66. i need the actual bulb socket that fits into the red housing. the electrodes in the socket areshot and the copper inside broke, so socket needed.where to get? does the dorman universal socket fit? need to cut wires and go to auto parts store?help needed...thanks. Quote Link to comment Share on other sites More sharing options...
Buggytrashdad Posted November 19, 2015 Share Posted November 19, 2015 Sometimes the have the center section with the solder points and pigtail wires. Try Autozone, or one of the auto parts supply houses. You may need to bring yours in to match the alignment key. You may have to get creative. Quote Link to comment Share on other sites More sharing options...
foolofsand Posted November 19, 2015 Author Share Posted November 19, 2015 (edited) Sometimes the have the center section with the solder points and pigtail wires. Try Autozone, or one of the auto parts supply houses. You may need to bring yours in to match the alignment key. You may have to get creative. no one had jack. i just bought one and modified the red light box up high so the socket would fit in and then piddled with the wires to make the turn stop brake and running all work. yippee, its done thanks for response. Edited November 19, 2015 by foolofsand Quote Link to comment Share on other sites More sharing options...
