500 HP Supercharged Gen 1 Hayabusa Engine Asking $4,000 : Cost= $14K
Call Danny 619 89 0 seven three too five
Newly built, Zero Miles. 2003, Gen 1 Hayabusa Supercharged Engine
Asking $4,000 OBO
Part Discription
Notes
Contion
Price New
Engine
Used
1800
Engine rebuild service
Service
1300
Head intake/exhaust porting
Service
500
Rotrex C38-81
575hp
New
2300
Custom Plenum (custom)
New
1000
Supercharger drive system (custom)
New
800
Bosh EV 14 Injectors, flow matched
New
350
Boost Pop off value
Used to control max boost curve
New
100
Tail Blow off Valve
New
240
Microtech LT4
Used
800
Fuel Rail material
New
34
Innercooler, Griffen
New
613
Innercooler Fans, Spal
New
78
Mini ChevyAlternator
New
86
APE head nuts
50
Windage Tray
New
42
Falicon Knife Con Rods
Slightly
Used
1160
Undercut, etc transmission service
New
950
Hay billet output shaft
New
314
APE cylinder studs
New
60
Cam Chain Conversion
New
231
81mm piston ring set
New
82
Bottom Gasket Set
New
43
Emissions block off plates
New
20
U/C 1 side only
New
40
Hard weld gear dogs
New
60
APE Shift Fork Shaft
New
60
APE Valve springs
New
110
Cometic Base Gasket
New
24
Aluminum Spacer Plate
New
60
JE Forged Aluminium Pistons
Slightly
Used
575
High pressure oil relief valve
New
80
OEM Cam Cover Gasket
New
40
OEM connecting rod berings
New
120
OEM crank bearings
New
120
High volume oil pump gear
New
110
Total Estimated Cost
$14,352
Call Danny 619 89 0 seven three too one
Edited by redequity
Major Price drop!
  • 4 weeks later...
  • 3 weeks later...
