jwcarguy Posted June 10, 2016 Share Posted June 10, 2016 (edited) Clearing out shop after move and various car buildsPrices do NOT include shipping from Las Vegas, NV 89131Will post all pics soon (alot of them!), or pm/ text for picsOff Road Parts:-Cables:- 1 pair of #4 push/ pull control shifter cables used, 2" throw/ travel, 55" overall, 42.5" bulkhead to bulkhead centers $80 pair - 1 #4 push/ pull control shifter cable , new, 1" throw/ travel, 79" overall, 69.5" bulkhead to bulkhead centers, from Kartek $60- 1 #3 push / pull throttle cable , new 3" throw/ travel, 140" overall, 126.5" clip to clip, from Kartek $40- 1 #3 push/ pull throttle cable, new, 3" throw/ travel, 156" overall, 142.5" clip to clip, from Kartek $40 SOLD!!- 1 PBS/ Mendeola S4 shifter, new, from PBS $60 SOLD!- 1 pair of CNC Turning/ Steering brake handle knobs Blue, new (just mock up, changed color) $20pr.- 1 Tilton oil / gear cooler pump w/ wiring, relay, used, cracked fan cover (#40-910 $12 to replace) $125 SOLD!- 1 Allstar Performance billet oil filter / ?? mount , new (#92046) $20 - 1 Tru-Cool/ LONG oil cooler with #10 an stainless braided hoses and fittings, used, (cooler is 11 x 11 x 1.5", hoses are 34" w/ 90 degree fittings, 38" w/ 45 degree fittings $75 SOLD!- 1 Aeromotive billet fuel filter mount, new $50Drivetrain:- 1 pair of Pro Am 934 Double Boot flanges (trans side w/ 1/2" holes)w/ outter boots & o-rings, need inner boots, mocked up $100 pair SOLD!- 1 934 33 spline 300m axle, low use, 34.5" overall, (one end trimmed down 3" spline & 4" spline lengths) $300Springs/ parts:- 1 pair of King coil springs for 2.0" c/o shocks (#2.5-12.00-400) new $100pr- 1 pair of King coil springs for 2.0" c/o shocks (#2.5-12.00-500) used half season $60pr- 1 pair of King lower spring retaining plates (flat) for 2.0" c/o shocks new $40pr SOLD!Rod ends & threaded bungs;- 2 5/8"-18 Hex RH bungs for 1" tube, (don't recall for which tube size, bung is .748" od @ tube insert end) new $15pr SOLD!- 2 5/8"-18 Smooth RH bungs for 1" tube (don't recall for which tube size, bung is .807 od @tube insert end) new $15pr SOLD!- 4 5/8"-18 RH & LH (2 of ea) Chromoly rod ends w/ 1/2" hole $20 ea SOLD!- 4 1/2"-20 RH & LH (2 of ea) Chromoly rod ends w/ 1/2" hole w/ smooth end threaded bungs for .065" wall 1" tube and jam nuts $30 ea SOLD!LS / Vortec engine parts:- 1 SPEC steel flywheel, light use $150 SOLD!- 1 pair of RSI Billet Fuel Rails, black (bought for stock LS3 manifold, but not correct size) (see pics for dims) with new fittings also, used SS crossover I had $140 SOLD!- 1 BTR (Brian Tooley Racing Stage 4 LS3 n/a cam (233/250, 619/595 113+5 LSA , 3 bolt) used 2500 miles $300 SOLD!- 1 Comp Cams cam w/ XE-R lobes (224/236, 581/602 113 LSA ,3 bolt) used low miles $300 SOLD!- 1 GM stock LS3 cam (#3063 ,single bolt) low mileage take out $50 SOLD! - 1 GM stock LS2/ LS3/ LS7 fuel rail (new take off) $80 SOLD!- 1 3 bolt throttle body to 4 bolt throttle body billet adapter w/ o-ring, used $40 SOLD!- 1 set of MSD spark plug wires for LS1/2/3/6/7 , low use $30 SOLD!- 1 set of GM stock take off LS3 spark plug wires , low miles $20 SOLD!- 1 GM LS3 LS7 card style MAF Sensor with 4" dia alum tube and welded bung, tube length is 4", used $120 SOLD!- 1 Stainless steel 4" dia " Y air intake tube", has slight bend ,(see pic) 14" overall, 5 1/2" tall, used $80 SOLD!- variety of lengths of 4" dia. aluminum intake tubing & rubber couplers (2@ 5 1/2", 2@ 4 7/8", 1 2 5/8" w/ 9/16" hole, 1@ 12") couplers are 2 3/4" & 3", used, Offers ? SOLD!- 1 Throttle cable adapter (Morse style cable to cable throttle body DBC) 10 1/4" long, used $10 SOLD!- 1 pair of GM LS3 rocker stands (, 1 pair used) #12600936 , $10 -used pr SOLD!- 1 pair of GM LS1/ Vortec rocker stands, used $10- 1 GM "LS6" oil pump,(#12556436) new, bolted to engine, then removed, never run $70 SOLD! - 1 GM Gen III knock sensor harness, used, $15- multiple sets of 5 GM/ aftermarket LS1 / LS6 Fuel Rail Cover mounting studs $50/ set of 5- 1 set of 16 Texas Speed #25-7450 7.450" .080 wall Pushrod set, new in box $90Other:- 1 pair of Rigid Industries Dually LED lights, Amber & flood pattern, new, but mocked up and chassis sat out in sun, black is faded a bit w/ connectors/ plugs $100 SOLD!!- 2 SPAL 14" Electric fans, curved blade, new, but mocked up and chassis sat out in sun, fan "grilles" have a few missing ribs, never used $75 ea SOLD!- 1 pair of weld in seat mounting brackets, 18" center to center spacing, new $40pr SOLD!please pm/ call/ text (702)677-4085Thanks, Jeff Edited October 6, 2017 by jwcarguy Quote Link to comment Share on other sites More sharing options...
White Rhino Posted June 10, 2016 Share Posted June 10, 2016 Do u have a spare LS oil pan ? Didn't see one but thought I'd ask. Thanks Quote Link to comment Share on other sites More sharing options...
jwcarguy Posted June 10, 2016 Author Share Posted June 10, 2016 Which style are you looking for? I think that I just have a newer truck oil pan setup left right now Jeff Quote Link to comment Share on other sites More sharing options...
White Rhino Posted June 20, 2016 Share Posted June 20, 2016 Sorry. I was off for awhile I'll take a pic of what I need Thanks Quote Link to comment Share on other sites More sharing options...
jwcarguy Posted July 24, 2016 Author Share Posted July 24, 2016 list updated Quote Link to comment Share on other sites More sharing options...
