Universal 24' Stacker trailer hydraulic lift
HOTRNHELL
Who's had enough trying to wedge all the gear in too small of a trailer?  Here you go time to step up to a Stacker and make life easy.
'08 Universal 24' Stacker.
24' box, 13.5" tall, 102" wide, 98" rear door opening,  22'3" to cabinet,  7'3" between wheel wells,  aluminum roof aluminum skins, 25,000 weight capacity.
New Electric tongue jack
New marine deep cycle batteries ( just purchased and  installed yesterday)
Fresh  tires all around ST235/85R 16's.  Sailun S637's  (new spare on matching rim mounted inside)
Fresh bearings and brakes pads last year
Electric over hydraulic brakes
250 watt solar panel and charge controller
1750 watt inverter
100 Gal water tank
75Gal fuel tank with elec pump
Two huge aluminum storage boxes
Stainless top work bench
Aluminium helmet holders, headset holders, etc
LED lights everywhere  inside and out.  super bright inside and enough to light up the whole camp or pit area.
New Weight distribution hitch and bars available if needed.
Asking $26.5K
SIX ZERO TWO 361-83 seven 2
Located in Henderson NV
  • 7 months later...
