Toyhauler Water heater issue
Dune Cruzer
Ventured out to D from 2/13-2/18/23, water heater was working fine. On 2/16 it decided to go AWOL. Fuses all check out. Not sure what else to check. Unit is a 2018 Jayco Talon 320T. Currently I'm out of state, so unfortunately unable to provide any further info until I return. Any tips/tricks/guidance is much appreciated!
Have someone turn the water heater on while you are outside at the water heater. See if you can hear the gas valve open when it starts its cycle. If it does, then see if the igniter is sparking. I've replaced just about every component on mine over the years. lol Gas valve, ignitor and board. All very things are pretty common failures and easy to replace. Not very expensive either. You just need to troubleshoot it.
