Ross and Alice Posted January 19, 2006 Share Posted January 19, 2006 OK now,, it seems to me that if you go to a larger dia rear tire and wheel, this will slightly increase your power, but decrease your top speed slightly. Perhaps not even noticeable,,,, but bigger is slower with power, smaller is faster with less power. The tire store guy disagrees,,, Who's correct??? Quote Link to comment Share on other sites More sharing options...
lvnalolife Posted January 19, 2006 Share Posted January 19, 2006 The bigger tire, the harder it is to spin, therefore less power, but if you have the power it will give you more top end. Think about it in terms of real trucks. See how slow and hard it is for the lifted trucks to take off while a stock truck of the same model will smoke it off the line. Once the lifted trucks get moving they will have a higher top speed at the same rpm as the stock truck. So as you can see, you don't ever get more power, you just gain in how you want ot use it. Smaller tire, quicker out of the hole, bigger tire, more top end. But be careful sometimes the bigger tire will hurt you if you are trying to haul a$$ up a big hill, if your quad doesn't have enough power to turn them. Hope this helps. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted January 19, 2006 Share Posted January 19, 2006 Taller tire- requires more power to turn/ higher top speed due to "taller"gearing Smaller tire- easier to spin/ less top speed due to "shorter" gearing Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted January 19, 2006 Author Share Posted January 19, 2006 Think of it this way: If you have a larger rear sprocket on your quad,, then you have a slower top but more powerful low end. The same principal should apply to the larger dia tire and wheel. Bigger dia rear tire and wheel = increased low end power lower top end speed Smaller dia tire and wheel = less low end power but more top end Quote Link to comment Share on other sites More sharing options...
dunefreak Posted January 19, 2006 Share Posted January 19, 2006 Think of it this way: If you have a larger rear sproket on your quad,, then you have a slower but more powerful low end. The same principal should apply to the larger dia tire and wheel. Bigger dia rear tire and wheel + increased low end power lower topend speed Smaller dia tire and wheel + less low end power but more top end You can't look at it that way. Yes a larger rear sprocket gives you a more powerful low end. The reason that makes it like that is cause the wheel speed is being decreased causing the eng to turn more rpm's. If you add height to the wheel/tire- you are making the revolutions of the wheel take longer to complete thus making the engine rpm's lower and making it lug down. Hope that didn't sound too confusing. :huh: Quote Link to comment Share on other sites More sharing options...
wingnut Posted January 19, 2006 Share Posted January 19, 2006 Taller tires will cost you bottom end, but increase top speed. Quote Link to comment Share on other sites More sharing options...
Don29palms Posted January 20, 2006 Share Posted January 20, 2006 Taller tires have the same effect as putting on a smaller rear sprocket or a larger front sprocket. No matter what you do to your tires it will not effect the horsepower output of your motor . It will effect how the horsepower is used and at what RPM it is used. It takes more horsepower to spin a taller tire than a shorter tire for many reasons. The main reason is, as stated before, a change in gearing ratios. Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted January 20, 2006 Author Share Posted January 20, 2006 OK,, that explains it. I'm ordering paddles for sons z50 and I'll stay at stock size or slightly smaller. Thanks for all the imput. Quote Link to comment Share on other sites More sharing options...
Don29palms Posted January 20, 2006 Share Posted January 20, 2006 I know Sand Tires Unlimited makes those tires. They shave down stock tires and bond on the paddles. Quote Link to comment Share on other sites More sharing options...
Ross and Alice Posted January 20, 2006 Author Share Posted January 20, 2006 I know Sand Tires Unlimited makes those tires. They shave down stock tires and bond on the paddles. Thanks. They Don't answer their e amils or the phone,, but I'll check again. I found a set from Gecko too. Quote Link to comment Share on other sites More sharing options...
