HappyHour Posted March 12, 2007 Share Posted March 12, 2007 Just wondering some of your takes on this. I have a crack that developed, but I don't know how long it's been there. It's in the front of my car and comes off a weld. Now my question is........if I baby the car this weekend until Saturday afternoon, do you think I'll have an issue with it???? :icon_twisted: I wouldn't want to pay the welder guy out there a ton of cash to spot weld a crack so it doesn't go any further. Quote Link to comment Share on other sites More sharing options...
offroadracer Posted March 12, 2007 Share Posted March 12, 2007 If its cracked ,it going to get worse and go further, especially if its at a susp. mount point..You should have it sleeved and rewelded befor driving it anymore!!!! even puttin the car around its gonna flex Quote Link to comment Share on other sites More sharing options...
barefoot bob Posted March 12, 2007 Share Posted March 12, 2007 If its cracked ,it going to get worse and go further, especially if its at a susp. mount point..You should have it sleeved and rewelded befor driving it anymore!!!! even puttin the car around its gonna flex the offroad one is correct at minimum go get it welded.................................................... shouldn't cost but a lil bit...... Quote Link to comment Share on other sites More sharing options...
barneycar Posted March 12, 2007 Share Posted March 12, 2007 need to get it welded because puttin around is no fun Quote Link to comment Share on other sites More sharing options...
ct500lt Posted March 13, 2007 Share Posted March 13, 2007 Call Sean at VSM. He can probably fix it pretty quick. 759-5966 Quote Link to comment Share on other sites More sharing options...
dunefreak Posted March 13, 2007 Share Posted March 13, 2007 Call Sean at VSM. He can probably fix it pretty quick. 759-5966 Happyhour isn't in vegas, so I don't think that will be that fast for him. Quote Link to comment Share on other sites More sharing options...
mineurbiz Posted March 13, 2007 Share Posted March 13, 2007 If its cracked ,it going to get worse and go further, especially if its at a susp. mount point..You should have it sleeved and rewelded befor driving it anymore!!!! even puttin the car around its gonna flex So why do you have to sleeve it, won't welding it hold good, or is that just a weak point that you want to strengthen? Sorry just trying to learn, would love to learn how to weld. Quote Link to comment Share on other sites More sharing options...
mtwalet Posted March 13, 2007 Share Posted March 13, 2007 (edited) ok when you weld on top of a crack the heat goes threw the crack to other side aka inside the tube.weeking the metal around the crack making it weak. if you sleeve the tube you get twice the stregth back and your mind is not going to worry about the weld anymore. stronger and better to do that then just welding on top of the crack also if you want to learn how to weld just save some cash go buy a small 110 mig welder that is pretty much what you need to learn and just strat praticeing welders arnt that much Edited March 13, 2007 by mtwalet Quote Link to comment Share on other sites More sharing options...
offroadracer Posted March 13, 2007 Share Posted March 13, 2007 (edited) So why do you have to sleeve it, won't welding it hold good, or is that just a weak point that you want to strengthen? Sorry just trying to learn, would love to learn how to weld. What mtwalet said is true.....the tube from prior weld has already been welded(which had heat to it) unless it has been nealed which if it is not chromoly more than likely it was just welded......and just rewelding the crack is going to be weak and give you issues,not to mention welding over cracks would make it look like a hat full of smashed a-holes but the sleeve will give it strength , and should be a problem later down the road..hope that helps :mc_smiley: Edited March 13, 2007 by OFFROADRACER Quote Link to comment Share on other sites More sharing options...
BIG RICK Posted March 13, 2007 Share Posted March 13, 2007 Thats why when you build these buggies they should be (PRE-STRESSED) but dont think many do that. send me pics of where its at. i'll look at it I can bring my welder out if its fixable. i wont charge you anything. but do send pics of the crack. let me know asap Quote Link to comment Share on other sites More sharing options...
BIG RICK Posted March 13, 2007 Share Posted March 13, 2007 Thats why when you build these buggies they should be (PRE-STRESSED) but dont think many do that. send pics of where its at. I can bring out my welder or you can bring it to my house let me look at it to maybe weld it for ya. I wouldn't charge ya. *QUICK QUESTION WOULD YOU RATHER HAVE SOMETHING SNAP OR JUST BEND ITS LIKE (BOLTS) PEOPLE THINK GRADE 8 BOLTS ARE THE BEST ON THINGS BUT IT DEPENDS ON WHAT YOUR DOING WITH THEM. SOMETIMES HAVING GRADE 5 STRETCH IS BETTER THAN HAVING GRADE 8 SNAP. SOMETIMES THINGS ARE BUILT THAT WAY FOR A REASON. *EXAMPLE: BRAKES alot of people like using lifetime warranty brakes on their cars, but what happens is. the brakes dont wear out,BUT the rotors do. which is cheaper to replace. (answer) not the rotors. Sorry, I just think different than most. ***He is right you do need to anneal the metal afterwards to strengthen it. but otherwise let it cool (slowly) dont throw water on it to cool it off otherwise it will snap when or if it breaks. I dont believe in sleeving things. Quote Link to comment Share on other sites More sharing options...
sanddunesaddict Posted March 13, 2007 Share Posted March 13, 2007 ^^^^ So I gues Black Beauty lasting for over 20 years and being welded and sleeved and welded and who the hell knows what else,then I roll it and nothing breaks....lucky I know but a properly done repair job is just as strong or stonger than original. Quote Link to comment Share on other sites More sharing options...
BIG RICK Posted March 14, 2007 Share Posted March 14, 2007 typically your weld (should be) stronger than the surrounding area anyway. I'm not trying to be a smart a$$. I do have credentials :mc_smiley: Before I started my new business. I was a CERTIFIED MASTER FABRICATOR. I built aluminum trusses. and Custom Flying Effects for movies and theatre for many many yrs. I had to know my (shiat) to fly these movie,tv stars or they would fall to most likely there death. KINDA LIKE SUPERMAN... worked as a news paper guy by day and was superman by night Quote Link to comment Share on other sites More sharing options...
mineurbiz Posted March 14, 2007 Share Posted March 14, 2007 Very cool guys thanks for the education!!! Quote Link to comment Share on other sites More sharing options...
