changing rhino rear pads-- help please!
mrmotard
im in the process of changing the rear brake pads on my 05 rhino-- ive got the new pads on, but there isnt enough room between the pads to slip the over the rotor :beercheers: -- do any of you have suggestions on how to spread the brake piston a bit so i can get the disc between the new pads??? any help would be greatly appreciated!!! BRRRRAAAAPPP!!!
just figured it out!! no you dont want to use a clamp-- the actual piston itself turns, and rotates itself back into the caliper-- im assuming its threaded on the inside-- but its all back together now!!! thx though!! BRAAAAPPPP!!!!!
