yfz 450 rebuild
dooogie
my 04 yfz 450 finally let me down. the crank seized to the rod. who does everybody recomend to put it back together, and still screeeam, and still be reliable :dope:
wr crank with cp 12:5 compression if you still want to stay on pump gas. 14:1 for race gas, still as reliable. Stick with CP pistons.
Do you want to just rebuild or build it up? The WR crank is a good idea and the 14:1 CP piston (I have a CP also) are very nice. Make sure you have the oil mod done when you rebuild it. There are some great builders out there, that can add these parts and keep it very reliable.
Kenz Cycle Tech (Did mine)
KBR
MADD
Some guys have talked about power house, he is here local.
