bubba13 Posted May 21, 2007 Share Posted May 21, 2007 i got a 97 banshee i have been having prob with it lately it runs fine but at low rpm it bogs down and u have to push or pull it with a car to start it it wont start by kicking it i have change the jets new plugs just rebuilt the motor it has a new wiring harness also has a coolhead any help? Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 21, 2007 Author Share Posted May 21, 2007 any buddy in the vegas area with some help my number is 622 5200 im trying to fix it by memorial day weekend..thanks Quote Link to comment Share on other sites More sharing options...
Randog Posted May 21, 2007 Share Posted May 21, 2007 Hey Bubba, I had an 87' banshee that had problems starting just like yours. Ran great too. I changed thing after thing, then finally I replaced the CDI box and Boo-Ya. If they have the same system and you haven't swapped it out, It's an easy check. Try-it. Good luck. R- Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 21, 2007 Author Share Posted May 21, 2007 i will thanks i havent tryed it yet but it has good spark and every thing just wont start by kicking it Quote Link to comment Share on other sites More sharing options...
vegas style Posted May 21, 2007 Share Posted May 21, 2007 if you get stuck take it by atv cycle sports they do alot of banshees Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 21, 2007 Author Share Posted May 21, 2007 i tryed a cdi but no diff. its like if you dont keep reving it if u let the rpm get low it bogs and dies out then u have to pull start it ..hmmm i thought it might be the carbs :dance: Quote Link to comment Share on other sites More sharing options...
lvnalolife Posted May 21, 2007 Share Posted May 21, 2007 i tryed a cdi but no diff. its like if you dont keep reving it if u let the rpm get low it bogs and dies out then u have to pull start it ..hmmm i thought it might be the carbs :dance: Sounds like you are flooding it out. It might be set too fat in the low end. I would try dropping the needles down one setting and see how that does. (Down one setting is up on the needle) Other issue could be too lean in the bottom cuasing it to run out of gas at idle. If that is the case, maybe pull the needle up one setting. Let me know if this helps. PM me if you need any help. Quote Link to comment Share on other sites More sharing options...
JoeDuner Posted May 21, 2007 Share Posted May 21, 2007 Might want to check the float levels as well. To high and it will flood out. Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 22, 2007 Author Share Posted May 22, 2007 also when u kick it it kinda not backfires but like a poof of air not like a pop but a poof Quote Link to comment Share on other sites More sharing options...
dinicolada Posted May 22, 2007 Share Posted May 22, 2007 CK compression!!!! :dance: :rainbow1: Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 22, 2007 Author Share Posted May 22, 2007 k it used to run fine then i rebuilt it and now it doesnt like to run hmm for sell 1 banshee needs work..1800 Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 22, 2007 Author Share Posted May 22, 2007 i want to check the compression but i dont know where to get a gauge at Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 22, 2007 Author Share Posted May 22, 2007 k i did the compression test the left side is 130 and the right is 60 so i guess something happen to the right side maybe thats been the prob the hole time Quote Link to comment Share on other sites More sharing options...
JoeDuner Posted May 22, 2007 Share Posted May 22, 2007 Pretty Much!!!!! Quote Link to comment Share on other sites More sharing options...
bubba13 Posted May 22, 2007 Author Share Posted May 22, 2007 ya ya thanks for everyones help new top end time ... but hopefully i can do it by this weekend.. Quote Link to comment Share on other sites More sharing options...
VAZEE*BROS*MOTORSPORTS Posted May 24, 2007 Share Posted May 24, 2007 have you Check the reeds, or the timing ? Any other questions please give us a call 702-240-QUAD. Thanks Quote Link to comment Share on other sites More sharing options...
evilbeaver Posted May 25, 2007 Share Posted May 25, 2007 (edited) they took care of me on my quad bought me new cases and reasembled with no charge nuthing bad to say just took a lil to long but was well worth the wait thanks guys from atv cycle shop bike runs great i would take your banshee to them great servise.... Edited June 12, 2007 by evilbeaver Quote Link to comment Share on other sites More sharing options...
