mrmotard Posted July 16, 2007 Share Posted July 16, 2007 ok- need a lil help from you guys- i just sold my 97 chevy 3500 dully- and purchased a 2001 dodge 2500 4x4 cummins deisel-- hooked up my 20ft hauler to the new truck and headed out to marysvale a few weeks ago- and anytime any bigger car or truck went by me on the highway the trailer would start rocking,back and forth--- and when a semi went by -(pucker up) it was scary! :poop_hittin_the_fan: -- i have been towing this same trailer since 01 and it has never swayed at all-- no mater what was going by me or at any speed!! im using all the same stuff on the new truck- ball,weight dist., sway bar-- nothing has changed but the truck!! i had lowered the ball to the lowest seting on the hitch, but im thinking it might still be a little to high- it still angles back a little bit on flat ground!- so what do you guys think?? can any of you do a measurement from the ground to the ball on your trucks for me-- i guess i should have measured where it sat on my old truck before i traded it in!! thx for any help or info in advance!! - Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted July 16, 2007 Share Posted July 16, 2007 what do you carry in your hauler? was it loaded up the same as always? might wanna try full water in the tanks/more weight on the hitch.....might have had the scissor action going on :poop_hittin_the_fan: the only thing i have experienced with the trailer nose being too high/low is that when it was low, braking was the prob as the trailer would "dive" down, and tend to push the tow vehicle a little more... i never did experience the side to side stuff. btw...how fast were you going? Quote Link to comment Share on other sites More sharing options...
wingnut Posted July 16, 2007 Share Posted July 16, 2007 It's the setup Quote Link to comment Share on other sites More sharing options...
cj92345 Posted July 16, 2007 Share Posted July 16, 2007 your old truck was a dually...4 rear wheels tow much more stable. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted July 16, 2007 Share Posted July 16, 2007 Dually or not- it shouldn't sway like that. Try going one or two less links on the equalizer bar chains to add tongue weight. Quote Link to comment Share on other sites More sharing options...
offroadracer Posted July 16, 2007 Share Posted July 16, 2007 (edited) Dualleys do pull better!! but try moving your load around inside, and like freak said change the links on the equalizer .....mine does it too when a semi goes by its :poop_hittin_the_fan: and im pulling mine with a f-250 super crew Edited July 16, 2007 by OFFROADRACER Quote Link to comment Share on other sites More sharing options...
lvnalolife Posted July 16, 2007 Share Posted July 16, 2007 You really need to try and get the trailer as level as possible. Go buy a longer shank for your weight distribution and invest in a sway control. Quote Link to comment Share on other sites More sharing options...
mrmotard Posted July 16, 2007 Author Share Posted July 16, 2007 thx for the reply guys- to answer a few------ i have a sway bar sways at any speed over 60 when passed,or passing i tried coming home without the weight dist. at all-- no difference only had my rhino in it-and a trx250 before i had my dully i towed this trailer with a lowered V6 f150- and never had swaying issues!! the truck dosnt sway- it holds pretty true- but the trailer!! argh-- im thinking the best thing to do is what was stated in the previous post!! invest in a longer shank to lower the front end and get a little more tounge wieght!! Quote Link to comment Share on other sites More sharing options...
dunefreak Posted July 16, 2007 Share Posted July 16, 2007 I would check your tires on your truck. Are they E rated? Air pressure at the correct setting? Tires have alot to do with towing & trailer stability. Quote Link to comment Share on other sites More sharing options...
dunefreak Posted July 16, 2007 Share Posted July 16, 2007 Also: Is the trailer loaded exactly the same as before or has that changed since before? Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted July 16, 2007 Share Posted July 16, 2007 it could be that with it tilting up, more weight is placed on the rear axle, leaving you with a low tongue weight, causing this phenomenon is the rhino over the axles? with the bike behind it????? what do you have in front of your axles inside the trailer??? Quote Link to comment Share on other sites More sharing options...
mrmotard Posted July 16, 2007 Author Share Posted July 16, 2007 the rhino goes over the axles- forward just a little-- just light stuff behind it, and coolers in front of it-- ive been loading the same way for years-- the tires are BFG all terrain, and tire pressure is good!! Quote Link to comment Share on other sites More sharing options...
Dunerocket Posted July 16, 2007 Share Posted July 16, 2007 Hey Brad! I had the same problem with my trailer. You need to get the trailer level or down in front a little. If you are running the load leveler bars make sure they are not to tight this takes the weight off the back of your truck.(one reason so many people get stuck in the sand at Dumont) I allways try and load they heavy stuff over the axels and forward. It worked for me. Don T. Quote Link to comment Share on other sites More sharing options...
OGP Posted July 17, 2007 Share Posted July 17, 2007 I had the same speed wobble problem until I lowered the tongue of the trailer to a little below level. Now it tows rock solid. Quote Link to comment Share on other sites More sharing options...
OGP Posted July 17, 2007 Share Posted July 17, 2007 Hey Brad! I had the same problem with my trailer. You need to get the trailer level or down in front a little. If you are running the load leveler bars make sure they are not to tight this takes the weight off the back of your truck.(one reason so many people get stuck in the sand at Dumont) I allways try and load they heavy stuff over the axels and forward. It worked for me. Don T. Why does it matter if the links are tight or loose to prvent getting stuck? I need to know because I seem to get stuck alot out there when others dont. Quote Link to comment Share on other sites More sharing options...
raptoroy Posted July 17, 2007 Share Posted July 17, 2007 Because it distributes weight to the front axle and the trailer so that all the weight isn't on the rear. I have had this happen to me, I released distribution bars after someone told me and pulled right out. Quote Link to comment Share on other sites More sharing options...
Dunerocket Posted July 17, 2007 Share Posted July 17, 2007 that's it alot of people don't know how they work. years ago there was an add for a hitch company they had the rear wheels off the car and the hubs were not touching the ground. Quote Link to comment Share on other sites More sharing options...
sanddunesaddict Posted July 17, 2007 Share Posted July 17, 2007 that's it alot of people don't know how they work. years ago there was an add for a hitch company they had the rear wheels off the car and the hubs were not touching the ground. You can crank the bars up enough to take all the weight including the truck weight off the tires of the truck and put it all on the trailer. This is how you get stuck easier and also rip hitches off your truck like in Mike330r's case. Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted July 17, 2007 Share Posted July 17, 2007 with the terrain in the sand, people shouldn't have the weight distribution bars on anyhow. all that dipping and bobbing around can severely bend the tongue and frame of the trailer W/D hitches work good (on a paved road), but are not meant for off-road use Quote Link to comment Share on other sites More sharing options...
Dune Cruzer Posted July 18, 2007 Share Posted July 18, 2007 Wow! I'm surprised no one started another truck $hit talk thread here! Quote Link to comment Share on other sites More sharing options...
dunefreak Posted July 18, 2007 Share Posted July 18, 2007 Wow! I'm surprised no one started another truck $hit talk thread here! yeah no kidding! I think it's cause there's like 3 other topics that already went did. Quote Link to comment Share on other sites More sharing options...
barefoot bob Posted July 19, 2007 Share Posted July 19, 2007 anytime you have more tailweight than nose weight your gonna rock and roll weight forward lower your hitch dont expect the same ride as a dually with a non dually :icon_twisted: Quote Link to comment Share on other sites More sharing options...
Don29palms Posted July 20, 2007 Share Posted July 20, 2007 (edited) I also had the same problem. I lowered my hitch and lessened the tension on the distribution bars and it tows great now. That's the truck I have. Mine is a 2001 Dodge 2500 4X4 V10. Edited July 20, 2007 by Don29palms Quote Link to comment Share on other sites More sharing options...
aseman Posted August 1, 2007 Share Posted August 1, 2007 I also had the same problem. I lowered my hitch and lessened the tension on the distribution bars and it tows great now. That's the truck I have. Mine is a 2001 Dodge 2500 4X4 V10. Yes, definately like everyone's saying...lower the ball a little and/or increase the links on the weight distribution chain. I've had these problems in the past as well while towing my 23 footer. Also, check all the trailer tire pressures, make sure that one of them aren't low. Quote Link to comment Share on other sites More sharing options...
mrmotard Posted August 11, 2007 Author Share Posted August 11, 2007 thx to all for the info-- im gonna lower the ball about 2 inches-- see if that works!! thx again!! Quote Link to comment Share on other sites More sharing options...
