mex450 Posted August 9, 2007 Share Posted August 9, 2007 i got a yfz450 05, cams pipe and and most recent a high compresion piston, some say jetfuel111 from rebel or vpc 12 108 octane.. thanks... Quote Link to comment Share on other sites More sharing options...
cdavego Posted August 9, 2007 Share Posted August 9, 2007 no less than 105 Quote Link to comment Share on other sites More sharing options...
wingnut Posted August 9, 2007 Share Posted August 9, 2007 It depends on the compression. What did your engine builder tell u to run? Quote Link to comment Share on other sites More sharing options...
Vegas FX400 Posted August 9, 2007 Share Posted August 9, 2007 you can only get 100 from rebel, not 111 Quote Link to comment Share on other sites More sharing options...
offroadracer Posted August 9, 2007 Share Posted August 9, 2007 I think the rebel at sahara an I15 (rebel distributor) might have it .. Quote Link to comment Share on other sites More sharing options...
cdavego Posted August 9, 2007 Share Posted August 9, 2007 yes they do have 110 at that local from the pump Quote Link to comment Share on other sites More sharing options...
mineurbiz Posted August 9, 2007 Share Posted August 9, 2007 depends on your compression Quote Link to comment Share on other sites More sharing options...
EY3BA11 Posted August 10, 2007 Share Posted August 10, 2007 you can probably get away with a 60/40 mix of c12 - 91 and be ok.. or just straight c12 Quote Link to comment Share on other sites More sharing options...
JoeDuner Posted August 10, 2007 Share Posted August 10, 2007 I would try the E85 Quote Link to comment Share on other sites More sharing options...
CaptNkllm Posted August 11, 2007 Share Posted August 11, 2007 ISBB said: you can probably get away with a 60/40 mix of c12 - 91 and be ok.. or just straight c12 agreed!! or a 50/50 would probably be ok also.. rebel has the 110 at the sahara highland store but from what iwas told by a supplier was that its really 107 at the pump from it being exposed to the atmosphere.(?) CApt Quote Link to comment Share on other sites More sharing options...
busa boy Posted November 6, 2007 Share Posted November 6, 2007 you should get some aviation gas or comonly known as "Avgas". It is a 100 octane gas used in air planes, what is nice about is that is has a higher content of lead in it than other gases. It is a hell lot cheaper than racing fuel, mabey 4$ a gallon. One draw back is that it might make your engine run a little bit lean, I not certian but it may concidering that it is used at 30,000 feet. And if your compersion is high and you need a little bit more octane put some octane boots addetive in it. I have a busa in a Raptor 660 frame and it loves the Avgas. Quote Link to comment Share on other sites More sharing options...
RAGDOLL MX Posted November 6, 2007 Share Posted November 6, 2007 DIESEL.... i use pump gas 91....and then i use race gas at times..just depends on the price at the time...bike does run better on race gas from Rebel. Quote Link to comment Share on other sites More sharing options...
Sand_YFZ Posted November 6, 2007 Share Posted November 6, 2007 My compression on my YFZ501 is around 14.25.1 or more.I usually run c12,but ive ran the Rebel Rocket Fuel brand stuff.Its leaded 111 i think they claim.It runs well also.VP U4.2 will work also.I used to run VP u2 with my 14.1 stockbore.The Rebel Rocket Fuel is pretty affordable.Like 6 bucks a gallon.VP C12 is about $55 for 5 gallons.U4.2 is 100 octane oxy fuel that will work great with high compression motors and is about $60 for 5 gallons.Ive also ran 10-15% methanol with leaded 100 octane which runs really well too.Lots of options just depends on what you need performance wise or if you just want it to run.I think c12 and c14 are nice solid running affordasble fuels.The Rocket Fuel at Rebel is a budget minded alternative.Allthe others are for trying to squeeze more HP with fuel.Then you can always run a little nitro.That was more trouble than it was worth.Did that once and gave up on it. Quote Link to comment Share on other sites More sharing options...
