Warrior07 Posted August 15, 2007 Share Posted August 15, 2007 ok so i got a nail in one of my toyhauler tires . what would you do replace it or fix it and just use it as a spare. and would you feel comfortable using it as a spare to limp back home . being that its a trailer loaded at 10,000 lbs . Quote Link to comment Share on other sites More sharing options...
YamaPimp Posted August 15, 2007 Share Posted August 15, 2007 ok so i got a nail in one of my toyhauler tires . what would you do replace it or fix it and just use it as a spare. and would you feel comfortable using it as a spare to limp back home . being that its a trailer loaded at 10,000 lbs . I would just fix it and keep using it. Quote Link to comment Share on other sites More sharing options...
Randog Posted August 15, 2007 Share Posted August 15, 2007 ok so i got a nail in one of my toyhauler tires . what would you do replace it or fix it and just use it as a spare. and would you feel comfortable using it as a spare to limp back home . being that its a trailer loaded at 10,000 lbs . That's your call Pete. I'd replace it. Nothing worse than a blowout that rips-up your trailer. Then putting on a spare with a patch in it. Not comforting. Where ever you skimp, will cost more in the long run. Yeah, Nobody said this dune sport is or was ever cheap. Quote Link to comment Share on other sites More sharing options...
Warrior07 Posted August 15, 2007 Author Share Posted August 15, 2007 That's your call Pete. I'd replace it. Nothing worse than a blowout that rips-up your trailer. Then putting on a spare with a patch in it. Not comforting. Where ever you skimp, will cost more in the long run. Yeah, Nobody said this dune sport is or was ever cheap. well i did by one of the tire guard plans but they will only pay to repair if it is repairable , or replace if not . then i have to send them the receipt for reimbursement pain in the arse . better off not buying it . Quote Link to comment Share on other sites More sharing options...
wingnut Posted August 15, 2007 Share Posted August 15, 2007 I've had a trailer tire repaired. It's been fine. That one tire isn't supporting your whole load. Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted August 15, 2007 Share Posted August 15, 2007 THIS IS just me.....i have had several nails in my tires over the years. The ones that are in the tread can be easily repaired to good as new. the ones close to the sidewall....youre gonna need a new tire if it is repairable....I would repair it and keep it on.....my 2 cents Quote Link to comment Share on other sites More sharing options...
offroadracer Posted August 15, 2007 Share Posted August 15, 2007 repairing it should be o.k..like wingnut said the whole 10,000lbs isnt on that one tire Quote Link to comment Share on other sites More sharing options...
JoeDuner Posted August 15, 2007 Share Posted August 15, 2007 I have had a nail in one of my tires for a year. It hasn't lost a pound of air, so I have left it alone. Now it's time for new tires all around. Quote Link to comment Share on other sites More sharing options...
powerhouse Posted August 16, 2007 Share Posted August 16, 2007 well i did by one of the tire guard plans but they will only pay to repair if it is repairable , or replace if not . then i have to send them the receipt for reimbursement pain in the arse . better off not buying it . if you have a tire plan , ice pick the side wall !! and get a new one Quote Link to comment Share on other sites More sharing options...
