White Rhino Posted September 24, 2007 Share Posted September 24, 2007 I have them, and went to hook up a hornblasters kit to it, but I get no voltage from the wires I thought they were. Anybody ever use them, if so, what wire (s) did you use? Quote Link to comment Share on other sites More sharing options...
Randog Posted September 24, 2007 Share Posted September 24, 2007 I've got em'. Never used em'. I'd like to know as well. Check the fuse box for fuses in the Upfitter spots. Maybe? Quote Link to comment Share on other sites More sharing options...
White Rhino Posted September 24, 2007 Author Share Posted September 24, 2007 Here is what I found out, and I tried these wires, no voltage? Fuses AND Relays in place get lights on the switches, but ??? You have the four blunt cut wires left (of the fuse box) to connect to your chosen accessories. To help you plan which accessories can be connected to each switch, use the following chart: AUX 1 1936 Circuit Number 30 Amp Capacity Orange / Light Green AUX 2 1933 Circuit Number 30 Amp Capacity Orange AUX 3 1934 Circuit Number 10 Amp Capacity Orange / Yellow AUX 4 1935 Circuit Number 10 Amp Capacity Orange / Light Blue They even have 4 wires form the fuse box to just under the hood, WHICH is cool (You'll see them just under the hood by the rirewall on the drivers side they are Red, White, Black, and Blue) This saves you from running wires from the fuse box to under the hood. Quote Link to comment Share on other sites More sharing options...
White Rhino Posted September 24, 2007 Author Share Posted September 24, 2007 Hey Randog I found 'em Dont be confused AS I WAS. There is a PTO wiring down there as well. I had to take the fuse box assy out (4 bolts 10mm) and behind there you will see them. MARKED CLEARY AUX 1-4 now for any people driving slow in the fast lane be prepared to be hornblastered Quote Link to comment Share on other sites More sharing options...
Randog Posted September 25, 2007 Share Posted September 25, 2007 Hey Randog I found 'em Dont be confused AS I WAS. There is a PTO wiring down there as well. I had to take the fuse box assy out (4 bolts 10mm) and behind there you will see them. MARKED CLEARY AUX 1-4 now for any people driving slow in the fast lane be prepared to be hornblastered Right on Paul! Thanks for all the info. :shout: Now go blast em' away. Quote Link to comment Share on other sites More sharing options...
Vegashd Posted October 17, 2007 Share Posted October 17, 2007 Hey Randog I found 'em Dont be confused AS I WAS. There is a PTO wiring down there as well. I had to take the fuse box assy out (4 bolts 10mm) and behind there you will see them. MARKED CLEARY AUX 1-4 now for any people driving slow in the fast lane be prepared to be hornblastered I was a little late here for this but I am glad you figured it out. I had the first 05 SD F250 on the lots in September of 05. I special ordcered it in April when I could get one ordered.. I had trouble figuring out the switch situation and their was no info anywhere on the stuff... what horns did you go with? Quote Link to comment Share on other sites More sharing options...
