limodriver Posted November 18, 2007 Share Posted November 18, 2007 Ok I have a 2000 3.5 Honda with a Link ecu and the motor has been running warmer than normal and also running lean. Fuel pressure is good and no vacum leaks that I have found. Motor is lacking power on the top end also. Checked everything I can think of and only found the o2 sensor to be giving a bad voltage signal so I replaced it and nothing changed. I also have the program to plug my ECU into my laptop but am not real familar with it so not sure what to do. Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
predu Posted November 18, 2007 Share Posted November 18, 2007 check your fuel filters poss bad fuel pump Quote Link to comment Share on other sites More sharing options...
JoeDuner Posted November 18, 2007 Share Posted November 18, 2007 it might be the injectors are dirty as well. Quote Link to comment Share on other sites More sharing options...
Don29palms Posted November 19, 2007 Share Posted November 19, 2007 I'm having the same problem with my car. It happened once before and it was because the injectors were plugged up. Quote Link to comment Share on other sites More sharing options...
limodriver Posted November 19, 2007 Author Share Posted November 19, 2007 Thanks! thats the only thing left that I have not looked at or done yet. Did you just run a good cleaner through them in the fuel or did you take them out and have them cleaned? Quote Link to comment Share on other sites More sharing options...
Don29palms Posted November 20, 2007 Share Posted November 20, 2007 Thanks! thats the only thing left that I have not looked at or done yet. Did you just run a good cleaner through them in the fuel or did you take them out and have them cleaned? I replaced mine but I'm going to send the ones I have now out to be cleaned and flow tested. It's cheaper than buying new injectors. Quote Link to comment Share on other sites More sharing options...
barefoot bob Posted November 26, 2007 Share Posted November 26, 2007 need bigger nozzels to let that sand pass through Quote Link to comment Share on other sites More sharing options...
