sandchicken Posted December 23, 2007 Share Posted December 23, 2007 while servicing my wifes quad the bottom bolt (oil drain) broke completely out of the oil tank i cant locate one ive called a bunch of places if any one has a stock or aftermarket tank for a 2001 raptor 660 please call me (Johnny) at (310) 633-1465. im hopefully leaving for dumont on christmas day. Quote Link to comment Share on other sites More sharing options...
ricepow Posted December 23, 2007 Share Posted December 23, 2007 while servicing my wifes quad the bottom bolt (oil drain) broke completely out of the oil tank i cant locate one ive called a bunch of places if any one has a stock or aftermarket tank for a 2001 raptor 660 please call me (Johnny) at (310) 633-1465. im hopefully leaving for dumont on christmas day. The bolt broke or the oil tank broke? You know you can go to Lowes or wherever and they have bits to extract broken bolts if it is only a broken bolt. They usually work pretty well. Just an idea. Good luck, hope you get it fixed. Quote Link to comment Share on other sites More sharing options...
sandchicken Posted December 23, 2007 Author Share Posted December 23, 2007 The bolt broke or the oil tank broke? You know you can go to Lowes or wherever and they have bits to extract broken bolts if it is only a broken bolt. They usually work pretty well. Just an idea. Good luck, hope you get it fixed. the tank itself broke the bung that the drain bolt goes into snapped off Quote Link to comment Share on other sites More sharing options...
sandaddict Posted December 23, 2007 Share Posted December 23, 2007 take it to welding shop and have them weld it is your steel Quote Link to comment Share on other sites More sharing options...
Dune Cruzer Posted December 24, 2007 Share Posted December 24, 2007 I believe umracing.com has an aluminum oil tank for your application, but it's rather costly for just having to replace a broken bolt. They're also located in LV if that helps. Good luck with the fix! Quote Link to comment Share on other sites More sharing options...
Raptor661 Posted January 31, 2008 Share Posted January 31, 2008 Mine broke on the bottom for what ever reason. They are an alum tank that are about as thick as a beer can so there isnt much help in welding. I ended up buying on off of ebay, they are around 300 new and you can get a nice thick aftermarked for about 175. I woulndt suggest buying used tank b.c it will probably end up doing the same as what yours already did. Quote Link to comment Share on other sites More sharing options...
