Warrior07 Posted February 10, 2008 Share Posted February 10, 2008 So yesterday i was washing the trailer going thru it make sure everything works. so i turn on the heater ok it works now i turn it off and the sum biatch won't shut off unless i push in the main power switch. it stays off but once i hit the thermostat it comes on but won't shut off . :no_no: Quote Link to comment Share on other sites More sharing options...
dinicolada Posted February 10, 2008 Share Posted February 10, 2008 Pete what do you mean by wont turn off? Does the fan keep running but the burner turn off? Or are they both staying on? There is a time on the board that will keep the fan on after the burner goes out, it may run for a few minutes after you turns it off to cool the coils and purge out any unburt gas. :no_no: Quote Link to comment Share on other sites More sharing options...
TbonesMalones Posted February 10, 2008 Share Posted February 10, 2008 Sounds like the T-Stat might be bad, I would pull off the T-stat face and see if the White(heat) wire is connected. If you disconnect the white wire and the fan contiunes to blow, your digital board is probably bad. Quote Link to comment Share on other sites More sharing options...
Warrior07 Posted February 11, 2008 Author Share Posted February 11, 2008 sorry false alarm it works now! Quote Link to comment Share on other sites More sharing options...
wingnut Posted February 11, 2008 Share Posted February 11, 2008 sorry false alarm it works now! Cool it started working again...............but I think you need to voluntarily ban yourself from DDR for no less than 72 hours!!!!!! :no_no: Quote Link to comment Share on other sites More sharing options...
TheAlaskan Posted February 11, 2008 Share Posted February 11, 2008 I agree with ^^^^^^^^ how am i supposed to know if i can crash your camp and drink your beer with false alarms like this? ...... :no_no: Quote Link to comment Share on other sites More sharing options...
Warrior07 Posted February 11, 2008 Author Share Posted February 11, 2008 (edited) :no_no: Cool it started working again...............but I think you need to voluntarily ban yourself from DDR for no less than 72 hours!!!!!! ok wingy dingy get the flames off your avator truck and will talk :worthless_without_pics: Edited February 11, 2008 by warrior07 Quote Link to comment Share on other sites More sharing options...
wingnut Posted February 11, 2008 Share Posted February 11, 2008 Ok.....as soon as you take that pic off DDR where yor truck got stuck at Logandale. You know the one where two drives don't even get stuck!!!!! DERRRR Quote Link to comment Share on other sites More sharing options...
Warrior07 Posted February 11, 2008 Author Share Posted February 11, 2008 Ok.....as soon as you take that pic off DDR where yor truck got stuck at Logandale. You know the one where two drives don't even get stuck!!!!! DERRRR Quote Link to comment Share on other sites More sharing options...
