HarleyR Posted April 2, 2008 Share Posted April 2, 2008 I got the 06 LTR 450 and I need to know what gear if any is 1 to 1 I would think 4th like a car transmission I have found a kick a$$ flat track in SC and would like to move the axle or countershaft sprockets around so I can run in 1 to 1 and keep the R's way up... just hitting the limiter before corner entry... I working on a front sway bar set up as well as getting some stagger in the rear tires.... Thanks for the help.... Harley Quote Link to comment Share on other sites More sharing options...
suzukilt Posted April 2, 2008 Share Posted April 2, 2008 google top speed calculator, it will ask your rpm, tire size, and tranny ratios. you can then play with the sprockets to the the final ratio and speed your looking for Quote Link to comment Share on other sites More sharing options...
HarleyR Posted April 3, 2008 Author Share Posted April 3, 2008 I can do the math to figure out what I need but I dont know RPM or tranny ratios or MPH.. I just need to know if theres a direct drive in the trans... Quote Link to comment Share on other sites More sharing options...
suzukilt Posted April 3, 2008 Share Posted April 3, 2008 I believe 4th is, all the dyno runs that where done on my bike are done in 4th gear.... hope this helps Quote Link to comment Share on other sites More sharing options...
