Warrior07 Posted May 3, 2008 Share Posted May 3, 2008 (edited) Has anybody put stock front rhino tires on 8 inch wide rims? reason being i got some new bling and there 8' wide so are the stock front tires . Edited May 3, 2008 by warrior07 Quote Link to comment Share on other sites More sharing options...
Warrior07 Posted May 4, 2008 Author Share Posted May 4, 2008 Quote Link to comment Share on other sites More sharing options...
MAXDOUT Posted May 5, 2008 Share Posted May 5, 2008 Quote Link to comment Share on other sites More sharing options...
YamaPimp Posted May 5, 2008 Share Posted May 5, 2008 Has anybody put stock front rhino tires on 8 inch wide rims? reason being i got some new bling and there 8' wide so are the stock front tires . I used the stock rears for the front on mine and scat tracs on rear. I have a set of stock fronts if you want them let me know. Quote Link to comment Share on other sites More sharing options...
Warrior07 Posted May 5, 2008 Author Share Posted May 5, 2008 I used the stock rears for the front on mine and scat tracs on rear. I have a set of stock fronts if you want them let me know. My front stocks are good going to mount the fronts today. See how they bead up if they look to iffy might have to get some rears to put in front . Quote Link to comment Share on other sites More sharing options...
YamaPimp Posted May 6, 2008 Share Posted May 6, 2008 With the stock rears on front and the haulers on back you can go anywhere in 2wd, you would be suprised. When you going too sand hollow? I will be there on mem day Quote Link to comment Share on other sites More sharing options...
