04 yfz450
quad~dizzle
is there a fill plug if so where is it at? if not how much do you put in? thanks.
There is a drain plug under the left side by the shifter, there is one on the bottom of the oil tank also. When you go to fill it back up put some in the crank case and then the oil tank.
Overhaul
Total amount
1.95 L (1.72 Imp qt, 2.06 US qt)
Quantity in oil tank
1.55 L (1.36 Imp qt, 1.64 US qt)
Quantity in crankcase
0.40 L (0.35 Imp qt, 0.42 US qt)
Periodic oil replacement
Total amount
1.75 L (1.54 Imp qt, 1.85 US qt)
0.20 L (0.18 Imp qt, 0.21 US qt)
With oil filter element replacement
Total amount
1.85 L (1.63 Imp qt, 1.96 US qt)
0.30 L (0.26 Imp qt, 0.32 US qt)
