Sandpirates2 Posted September 3, 2008 Share Posted September 3, 2008 (edited) Well, I finally got myself in a position that I need help big time and quickly. While backing up to the hauler (5th Wheel), I backed under the king pin, and suprise, when I went to hook up the safety cable for the brakes, and my electrical cable, the electrical was missing from the trailer. It seems that while I was backing up, somehow it got caught, and pulled, the cable from out of the elec box behind the 5th wheel, and I ended up with *&^@!#$&( WIRES......some of them I can trace back, but I've got three that I have no way to know where in that elec box they were connected. I'm supppose to be leaving Friday, but this could be a set back.....anyone out there know anything about this. 2008 Weekend Warrior LED3505 hooking to a 2006 F350. SP2 Edited September 3, 2008 by Sandpirates2 Quote Link to comment Share on other sites More sharing options...
MQUnlimited Posted September 3, 2008 Share Posted September 3, 2008 The wires should be the same on all 7 way plugs....if I was home, I'd look at them for you...maybe someone can look. Quote Link to comment Share on other sites More sharing options...
White Rhino Posted September 3, 2008 Share Posted September 3, 2008 I just replaced one this weekend The colors prety much match up to the replacement. I got mine at camp world on Boulder Hwy. Like $20 or so PM me if you have more ?? I can give you my cell and Id help you more if you like Quote Link to comment Share on other sites More sharing options...
ynot Posted September 3, 2008 Share Posted September 3, 2008 (edited) Are you talking about the wire that plugs into the truck or the other end that comes out of the trailer? If it's out of the truck that should be pretty simple but if your talking about the harness from the inside of the trailer out to the truck then I think you have a bigger problem. If the wires broke off inside you may not be able to trace them without getting very involved. this is one of the times I would say call Ken at Johhny walkers on Flamingo and Boulder Hwy and see if he can get you in before your trip. Edited September 3, 2008 by ynot Quote Link to comment Share on other sites More sharing options...
Sandpirates2 Posted September 3, 2008 Author Share Posted September 3, 2008 Thanks guys - it's the cable that comes out of the trailer. But it seems to have all terminated into a 2-gang elec box behind the king pin box. I can match 4 of the original terminations but I've got three that I have no flip'n idea. There's also a 3 terminal fuse box that's inline as well, of which two of the wires are broken off there, but the third is missing altogether. Camp World in Henderson is about 6 miles from the house, I'll see about calling them in the am. SP2 Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted September 3, 2008 Share Posted September 3, 2008 (edited) OH SNAP! 7 pin wiring diagram if you only have three....thats only 6 different combinations.....get started on it i hope the above link can help Edited September 3, 2008 by richard cheese Quote Link to comment Share on other sites More sharing options...
Sandpirates2 Posted September 3, 2008 Author Share Posted September 3, 2008 OH SNAP!7 pin wiring diagram if you only have three....thats only 6 different combinations.....get started on it i hope the above link can help Thanks Jason, the issue is that it's the internal wiring of the trailer where it connects to that diagram cable. The colors are different, and there wired into a 2 gang electrical box with termination points and fuses that have no identity. Hey when I I do a good job...... Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted September 3, 2008 Share Posted September 3, 2008 so you just cant try them all and do it by a process of elimination??? what about calling a rv repair shop and asking for some help ? Quote Link to comment Share on other sites More sharing options...
White Rhino Posted September 4, 2008 Share Posted September 4, 2008 ok you should have a green a red and a brown wire connected to the fuse block that goes to the trailer. Match those colors to the new whip. Green to green red to red and brown to brown. Those are your turn marker and stop lights. The next wire is blue from the new whip, mine went to two black like 14 guage wires these are your brakes!!! The next white wire from whip goes to two white wires from trailer and they are ground should terminate to lugs and a screw on the double gang box. Then a 10-12 guage black wire this is the charge wire should go to a circuit breaker (30 amp) that goes to another black wire pm the other side of the breaker (note this may also be a one way diode also sold at camping world next to the whips to prevent the trailer from draining the truck batts, also be sure to check 30 amp fuse above your batteries I bet it blew one of them) the last is yellow from the whip. This is not used on WW but cap it as it's aux power tow vehicle. That's it!!! Quote Link to comment Share on other sites More sharing options...
vegas style Posted September 4, 2008 Share Posted September 4, 2008 way to help out paul hope he reads this and can get it done. Quote Link to comment Share on other sites More sharing options...
White Rhino Posted September 4, 2008 Share Posted September 4, 2008 yeah hope he sees it. I just did mine so fresh in my mind Quote Link to comment Share on other sites More sharing options...
Sandpirates2 Posted September 4, 2008 Author Share Posted September 4, 2008 (edited) :beerbong: Paul, Dude I owe you a case of cool ones... I went back tonight after work, and had to get a new diode, the other one got pulled in half, but I went down the line, replaced one of the 7.5 fuses and double wired it to a break-away connector, so the next time I pull a stupid stunt, I might survive it. Anyway, took about 45 minutes, pulled it in and it all works well. The yellow wire got me, as I had heard it was what charged my Batt's. But everything turned out great. Thanks for the help, and next outting, I'll have that case for you for sure. Camp World did tell me that for $75 that would have done it. But after reading your note, It looked do-able for sure. Now were loading up the hauler and getting ready to hit Pismo on Saturday morning. Hey Cheese - were meeting friends up on the hill at Indian Hills Camp Friday night, so we wont be hitting the crib in Bako this weekend, but sure do appreicate the offers...look forward to seeing you guys in Oct in DD. :6pak: Thanks, SP2 Mike Edited September 4, 2008 by Sandpirates2 Quote Link to comment Share on other sites More sharing options...
Richard Cheese Posted September 4, 2008 Share Posted September 4, 2008 :beerbong: Paul, Dude I owe you a case of cool ones... I went back tonight after work, and had to get a new diode, the other one got pulled in half, but I went down the line, replaced one of the 7.5 fuses and double wired it to a break-away connector, so the next time I pull a stupid stunt, I might survive it. Anyway, took about 45 minutes, pulled it in and it all works well. The yellow wire got me, as I had heard it was what charged my Batt's. But everything turned out great. Thanks for the help, and next outting, I'll have that case for you for sure. Camp World did tell me that for $75 that would have done it. But after reading your note, It looked do-able for sure. Now were loading up the hauler and getting ready to hit Pismo on Saturday morning. Hey Cheese - were meeting friends up on the hill at Indian Hills Camp Friday night, so we wont be hitting the crib in Bako this weekend, but sure do appreicate the offers...look forward to seeing you guys in Oct in DD. :6pak: Thanks, SP2 Mike glad you got yo' :poop: fixed have fun @ the dunes!! Quote Link to comment Share on other sites More sharing options...
White Rhino Posted September 4, 2008 Share Posted September 4, 2008 awesome. glad you got it fixed!! Quote Link to comment Share on other sites More sharing options...
TheAlaskan Posted September 5, 2008 Share Posted September 5, 2008 Glad you got everything workin good Mike....Have a great trip! Way to step paul! I love this site for exaclty that reason! :6pak: Quote Link to comment Share on other sites More sharing options...
