weekend warrior - fuel pump
Guest bicket
hello all......i am a girl trying to figure out why my fuel pump keeps blowing fuses....any suggestions for a girl who doesn't know how to fix it and now my warranty is a big waste of paper...wa wa wa...we took it out for the weekend and the fuses kept blowing and all we were trying to use was the fuel pump. it is a 2008 weekend warrior...see my profile for a pic.
Thank you :freakin_nuts:
HMMMM our haulers seem to be doing the same time as each other. I went out to Utah a few weeks ago, worked fine, came back and went to get gas for the lawn mower, and same thing......
anyone else have this problem??
It was to fuggin hott to dive into it last weekend when I found out about this
Thanks :laughing:
We are having the exact same issue with our WW as well. We took it in to be looked at and was told it would be $800 to replace it. We didn't replace it, just keep extra fuses and foil on hand for now. :rainbow1: :banghead:
Any input is greatly appreciated.
I have a next level and some times the pump just wont run you can here it try to but just wont , I have never blown a fuse but do you think it could be the same problem?
that could actually be the ground connection on the pump itself....find where the ground is connected to the frame and see if that connection is loose. just tighten it
i climbed under my rig a couple months ago and tightened all ground connections, and things work much better than before :beercheers:
How did you get under the trailer? Are your axles flipped or did you jack it up? :slap::idiot:
i wedged your fat A$$ between the ground and the frame, then poured gravy down your gullet until my fat a$$ could fit underneath
FAT A$$
:beercheers:
Ok, I'm still trying to figure out how you got your Jack in the box sized head and 4 chins under there though????
  • 4 years later...
not quite, metal key may not work. $44--ouch!. most i have found are $15. i will call gpi tomorrow and see
if they still have the replacement gears for the m-55. thanks
Edited by foolofsand
