Richard Cheese Posted September 28, 2008 Share Posted September 28, 2008 i went to get gas out of the fuel station today. the pump worked the first time filling up the dump can. the next trip.....nothing...i checked the timer inside, reset it just in case....checked all the fuses on the fuse panel...everything was correct, but couldnt hear the pump working i go out to the station, flip the emergency shut off switch on and off a couple times, with the handle engaged, and it started working...so i began to fill up i started thinking about what could be wrong, and let off the handle, and reengaged it...again...nothing....pulled the handle...flipped the emergency switch, and bingo, it came back on again towards the end of the last fillup it was working the way it should have, with me being able to let off the trigger, and re-engage, and it continued to pump.. im thinking it may be the emergency shut off switch, but, again i wanted to check with the pros first :B Quote Link to comment Share on other sites More sharing options...
